More productive than ever. The Dell 20 Monitor P2017H brings a whole new level of productivity to the work place without sacrificing comfort and convenience.
Purposefully designed for comfort and convenience
With a full range of adjustable features, slim borders and multiple connectivity ports. -
Enhanced viewing experience
Dell ComfortView and flicker-free feature make work less strenuous when viewing vividly clear visuals across an ultrawide viewing angle. -
Reliable and responsible
Get complete piece of mind with Premium Panel Guarantee, Advanced Exchange Service and an eco-friendly design. -
A more seamless workflow
Slim borders create a smoother and less obstructed visual experience when working across multiple monitors. -
Versatility you can count on
Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference. -
More ways to stay connected
Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices.
- Dell P2017H - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Energy Class
- Class A+
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.271 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 46.2 cm x 18 cm x 33.9 cm
- 4.73 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class A+
- Diagonal Size
- 20"
- Viewable Size
- 19.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.271 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Ultra wide viewing angle, Flicker Free technology, Premium Panel Guarantee, Dell ComfortView
- Black
- 46.2 cm x 18 cm x 33.9 cm - with stand
- 4.73 kg
- HDMI , DisplayPort , VGA , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable - USB Type A to B
- Input Voltage
Sustainability Information
- ENERGY STAR Certified
