An ultra-wide viewing angle ensures that imagery stays sharp and colors are consistent for you and viewers sitting next to you. If your office is running applications designed to support a 16:10 aspect ratio, the Dell P2016 displays those applications the way they were intended, helping to maximize productivity across your office.
A bigger view, top-to-bottom
An ultra-wide viewing angle ensures that imagery stays sharp and colors are consistent for you and viewers sitting next to you. If your office is running applications designed to support a 16:10 aspect ratio, the Dell P2016 displays those applications the way they were intended, helping to maximize productivity across your office. -
Convenient and easy to use
Work comfortably with tilt, pivot, swivel and height adjustment capabilities. A VGA port makes it easy to connect to legacy PCs.
- Dell P2016 - LED monitor - 20" - with 3-years Premium Panel Exchange service
- LED-backlit LCD monitor - 20"
- USB 2.0 hub
- Panel Type
- IPS
- Native Resolution
- 1440 x 900 at 60 Hz
- Pixel Pitch
- 0.2915 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Black
- 45.52 cm x 18 cm x 35.1 cm
- 4.12 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC/CI, RoHS, TCO Displays
- 3 years warranty
- Bundled with
- 3-years Premium Panel Exchange service
- Display Type
- Diagonal Size
- 20"
- Viewable Size
- 19.45"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Native Resolution
- Pixel Pitch
- 0.2915 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 136.75 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, hue, aspect control
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- 72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, stand lock, BFR/PVC-free, Energy Gauge, Mercury free, backlight dimming control, arsenic-free glass
- Black
- 45.52 cm x 18 cm x 35.1 cm - with stand
- 4.12 kg
- Bundled with
- DisplayPort , VGA , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
- Tilt Angle
- -5.5/22
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- Flat Panel Mount Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 30 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 45.52 cm - depth: 18 cm - height: 35.1 cm - weight: 4.12 kg , Without stand - width: 45.52 cm - depth: 4.65 cm - height: 29.9 cm - weight: 2.34 kg
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
