Dell P2016 19.5" 1440x900 6ms VGA DisplayPort IPS LED Monitor
Quicklinx: BM8KWS00 Mfr#: 210-AFOR
An ultra-wide viewing angle ensures that imagery stays sharp and colors are consistent for you and viewers sitting next to you. If your office is running applications designed to support a 16:10 aspect ratio, the Dell P2016 displays those applications the way they were intended, helping to maximize productivity across your office.
  • A bigger view, top-to-bottom
  • Convenient and easy to use
    Work comfortably with tilt, pivot, swivel and height adjustment capabilities. A VGA port makes it easy to connect to legacy PCs.
Display Type
Diagonal Size
20"
Viewable Size
19.45"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Native Resolution
1440 x 900 at 60 Hz
Pixel Pitch
0.2915 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
6 ms (grey-to-grey with overdrive)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
136.75 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare, 3H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, stand lock, BFR/PVC-free, Energy Gauge, Mercury free, backlight dimming control, arsenic-free glass
45.52 cm x 18 cm x 35.1 cm - with stand
4.12 kg
Bundled with
3-years Premium Panel Exchange service
DisplayPort , VGA , USB 2.0 upstream , 2 x USB 2.0 downstream
Mechanical
Display Position Adjustments
Tilt Angle
-5.5/22
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
Stand, cable management cover
1 x DisplayPort cable , 1 x USB cable
Compatible with Windows 7
Plug and Play, DDC/CI, RoHS
Security Slot Type
Kensington security slot
30 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 45.52 cm - depth: 18 cm - height: 35.1 cm - weight: 4.12 kg , Without stand - width: 45.52 cm - depth: 4.65 cm - height: 29.9 cm - weight: 2.34 kg
Environmental Standards
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
