Enhance your productivity and liven up your entertainment with sharp screen quality, adjustable viewing features and excellent connectivity options.
Flexible viewing features
The Dell 19 monitor - P1914S adjusts to fit your style, whether you are at work or home. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort. P1914S easily transitions from landscape to portrait orientation for optimal viewing of lengthy web pages with less scrolling. -
Multiple connectivity options
A comprehensive range of analog and digital ports, and their accompanying cables, provides virtually all the connectivity options you'll need over the course of the day. -
Sharp screen clarity
Every detail is bright and clear with the crispness of a LED backlighting. -
Color clarity and consistency across an ultra-wide viewing angle
The in-plane switching (IPS) technology offers clear images with consistent and accurate colors from virtually any viewpoint. -
Designed for work and home
Designed to help get the job done quickly, the P1914S is excellent for systems driving business or education applications. -
Environment-conscious design
The Dell 19 monitor - P1914S meets the latest regulatory and environmental standards. -
Energy-efficient design
Manage power consumption wisely with PowerNap, enabled through the Dell display manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
- Dell P1914S - LED monitor - 19" - with 3-years Premium Panel Exchange service
- LED-backlit LCD monitor - 19"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.29 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 41.14 cm x 18 cm x 49.97 cm
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC/CI
- 3-year warranty
- Bundled with
- 3-years Premium Panel Exchange service
- Display Type
- Diagonal Size
- 19"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.29 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 81 kHz
- Video Bandwidth
- 135 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue
- PowerNap, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Image Enhance
- Black
- Bundled with
- DVI-D , DisplayPort , VGA , USB 2.0 upstream , 4 x USB 2.0 downstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), Dell Energy Smart, VESA interface support
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
- Input Voltage
- Power Consumption (Typical)
- 37 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- Without stand - width: 41.14 cm - depth: 4.65 cm - height: 33.64 cm - weight: 2.76 kg , With stand - width: 41.14 cm - depth: 18 cm - height: 49.97 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
