Dell P1914S 19" 1280x1024 8ms VGA DVI DisplayPort USB IPS LED Monitor - Black
Quicklinx: BR9PWS00 Mfr#: 210-AGJI
Enhance your productivity and liven up your entertainment with sharp screen quality, adjustable viewing features and excellent connectivity options.
  • Flexible viewing features
    The Dell 19 monitor - P1914S adjusts to fit your style, whether you are at work or home. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort. P1914S easily transitions from landscape to portrait orientation for optimal viewing of lengthy web pages with less scrolling.
  • Multiple connectivity options
    A comprehensive range of analog and digital ports, and their accompanying cables, provides virtually all the connectivity options you'll need over the course of the day.
  • Sharp screen clarity
    Every detail is bright and clear with the crispness of a LED backlighting.
  • Color clarity and consistency across an ultra-wide viewing angle
    The in-plane switching (IPS) technology offers clear images with consistent and accurate colors from virtually any viewpoint.
  • Designed for work and home
    Designed to help get the job done quickly, the P1914S is excellent for systems driving business or education applications.
  • Environment-conscious design
    The Dell 19 monitor - P1914S meets the latest regulatory and environmental standards.
  • Energy-efficient design
    Manage power consumption wisely with PowerNap, enabled through the Dell display manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
Dell P1914S - LED monitor - 19" - with 3-years Premium Panel Exchange service
LED-backlit LCD monitor - 19"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
41.14 cm x 18 cm x 49.97 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI
3-year warranty
Bundled with
Display Type
Diagonal Size
19"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 81 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue
PowerNap, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Image Enhance
Bundled with
DVI-D , DisplayPort , VGA , USB 2.0 upstream , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, VESA interface support
Stand, cable management cover
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
Input Voltage
Power Consumption (Typical)
37 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 41.14 cm - depth: 4.65 cm - height: 33.64 cm - weight: 2.76 kg , With stand - width: 41.14 cm - depth: 18 cm - height: 49.97 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
