Your basket is empty
Dell P1914S 19" 1280x1024 8ms VGA DVI DisplayPort USB IPS LED Monitor - Black
Quicklinx: BR9PWS00 Mfr#: 210-AGJI
Enhance your productivity and liven up your entertainment with sharp screen quality, adjustable viewing features and excellent connectivity options.
Dell P1914S - LED monitor - 19" - with 3-years Premium Panel Exchange service
LED-backlit LCD monitor - 19"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
41.14 cm x 18 cm x 49.97 cm
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, TCO Displays
3 years warranty
Bundled with
Display Type
Diagonal Size
19"
Viewable Size
19"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 81 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue
72% (CIE 1931) colour gamut, 83% (CIE 1976) colour gamut, PowerNap, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Image Enhance
Bundled with
DVI-D , DisplayPort , VGA , USB 2.0 upstream , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, VESA interface support
Stand, cable management cover
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
37 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 41.14 cm - depth: 4.65 cm - height: 33.64 cm - weight: 2.76 kg , With stand - width: 41.14 cm - depth: 18 cm - height: 49.97 cm
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BR9P C2G HDMI to DisplayPort Adapter Converter In Stock £33.81
BR9P C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £20.79
BR9P C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
BR9P C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £15.23
BR9P C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £11.68
