Product
Brand
Dell P1914S 19" 1280x1024 8ms VGA DisplayPort USB LED IPS Monitor
Quicklinx: 9ZTLWS00 Mfr#: 857-BBCC
Enhance your productivity and liven up your entertainment with sharp screen quality, adjustable viewing features and excellent connectivity options.
Please note this montior does not come with a stand
Dell P1914S - LED monitor - 19"
LED-backlit LCD monitor - 19"
USB Hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
41.14 cm x 4.65 cm x 33.64 cm
2.76 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TCO Displays
3 years warranty
Display Type
Diagonal Size
19"
Viewable Size
19"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 81 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
83% colour gamut, HDCP, PowerNap
41.14 cm x 4.65 cm x 33.64 cm - without stand
2.76 kg
DVI-D (HDCP) , DisplayPort , VGA , USB upstream , 3 x USB 3.0 downstream
Mechanical
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
TCO Displays
United Kingdom
Power Supply
Internal
AC 100/230 V (50/60 Hz)
16 Watt
Power Consumption Sleep
0.5 Watt
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
9ZTL C2G HDMI to DisplayPort Adapter Converter In Stock £35.84
9ZTL C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.03
9ZTL C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
9ZTL C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £18.15
9ZTL C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £16.14
9ZTL C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £12.36
