Brand
Dell OptiPlex Vertical Stand
Quicklinx: CMLSWS00 Mfr#: 482-BBBR
More than 50 in stock
£19.71 ex VAT
£23.65 inc VAT
The Dell OptiPlex Micro Vertical Stand is Designed for those with limited desk space, the Micro Vertical Stand instantly creates more room by dramatically reducing the OptiPlex footprint. This clean, simple stand is an easy way to safely configure an OptiPlex Micro systems in an upright position. It helps in minimize desktop clutter and aids in organization. Also provides easy access to all ports on your OptiPlex Micro system. With access clear to both the front and rear panels, the Micro Vertical Stand makes it easy to run appropriate cabling and connect peripherals. The vertical mounting option also provides a stylish look for workspaces requiring a specific aesthetic. Moreover, this compact and convenient solution seamlessly upgrades your OptiPlex experience.
  • Simple vertical placement for OptiPlex systems
    The Dell OptiPlex Micro Vertical Stand lets you mount an OptiPlex Micro PC vertically in any workspace. This clean, simple stand is an easy way to safely configure an OptiPlex Micro systems in an upright position.
  • Instantly create more room in your workspace
    Designed for those with limited desk space, the Micro Vertical Stand instantly creates more room by dramatically reducing the OptiPlex footprint. This helps minimize desktop clutter and aids in organization. The vertical mounting option also provides a stylish look for workspaces requiring a specific aesthetic.
  • Easy access to computing ports
    In addition to offering a space-saving mounting option, the vertical stand also provides easy access to all ports on your OptiPlex Micro system. With access clear to both the front and rear panels, the Micro Vertical Stand makes it easy to run appropriate cabling and connect peripherals.
  • An ideal companion for OptiPlex Micro systems
    The Dell OptiPlex Micro Vertical Stand has been specifically designed and tested for use with OptiPlex Micro systems. This compact and convenient solution seamlessly upgrades your OptiPlex experience.
Dell OptiPlex Micro Vertical Stand - system desk stand
System desk stand
OptiPlex 3020 (micro), 3040 (micro), 3046 (micro), 3050 (micro), 3070 (micro), 3090 (micro), 5050 (micro), 5070 (micro), 5080 (micro), 7040 (micro), 7050 (micro), 9020 (micro)
System desk stand
Dell OptiPlex 3020 (micro), 3040 (micro), 3046 (micro), 3050 (micro), 3070 (micro), 3090 (micro), 5050 (micro), 5070 (micro), 5080 (micro), 7040 (micro), 7050 (micro), 9020 (micro)
Brand: Dell
Stock Status: In stock
