Elegant and expansive
The brilliant edge-to-edge display makes it easy to present, share and display more onscreen information to reduce scrolling and improve productivity. -
Hear the meeting clearly
State-of-the-art noise reduction through Waves MaxxAudio Pro and the quad mic array enable crystal-clear collaboration up to 12 feet away. The premium integrated speakers allow for crisp communication. -
Enhanced security
The pop-up web camera hides safely out of sight when not in use and adds a layer of security with facial recognition. -
Stay connected with ease
Equipped with a side mounted USB Type-C for easy access and speedy data transfer and a USB PowerShare port to conveniently charge other devices even when the system is powered down. Plus, the included Media Card Reader SD4.0 allows for fast data transfer from a variety of memory cards. -
Multiple ways to display
DisplayPort and HDMI 2.0 ports provide modern digital connectivity with support for two additional monitors so you can view more information on screen without minimize or closing applications. -
Easy access
Thanks to a toolless design, you can slide off the back cover with minimum effort, allowing you to maintain and upgrade with ease.
- Dell OptiPlex 7760 All In One - all-in-one - Core i7 8700 3.2 GHz - vPro - 16 GB - SSD 512 GB - LED 27"
- Personal computer - all-in-one
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 16 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA
- Hard Drive
- SSD 512 GB - PCI Express - M.2
- Optical Storage
- No optical drive
- Card Reader
- Monitor
- 27" - LED - 3840 x 2160 (Ultra HD 4K) @ 60 Hz - 163 ppi
- Graphics Controller
- NVIDIA GeForce GTX 1050
- Video Memory
- 4 GB GDDR5 SDRAM
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, 802.11ac Wave 2, Bluetooth 5.0
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Silver
- 61.4 cm x 5.77 cm x 38.9 cm
- 8.41 kg
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- All-in-one - with height-adjustable stand
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Silver
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- 16 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 512 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 27"
- Native Resolution
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen Display
- Pixel Density (ppi)
- 163
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Pixel Pitch
- 0.1554 mm
- Response Time
- 25 ms
- Image Brightness
- 350 cd/m²
- Image Contrast Ratio
- 1350:1
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio, Wave MAXXAudio Pro
- Speakers Included
- 2 x right / left channel
Input Device
- Keyboard (on selected markets only)
Audio Input
- Quad array microphone
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- Remote Wake Up, PXE support
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- Bays
- Internal 2.5"
- Slots
- M.2 Card
- 2 x USB 3.1 Gen 1 (2 rear) (supports SmartPower On) , 1 x USB 3.1 Gen 1 (PowerShare) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x USB-C 3.1 Gen 2 , 1 x LAN (Gigabit Ethernet) - RJ-45 (1 rear) , 1 x HDMI output (1 rear) , 1 x DisplayPort (1 rear) , 1 x audio line-out (1 rear) , 1 x headphones/microphone
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Pricing Type
- Power supply
- Voltage Required
- Power Provided
- 240 Watt
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
- Software
- Microsoft Office (Trial)
- Dimensions & Weight Details
- 28.7 cm - 25.48 cm - 3.22 kg - stand
- 61.4 cm
- 5.77 cm
- 38.9 cm
- 8.41 kg
- Shipping Width
- 91.8 cm
- Shipping Depth
- 21.6 cm
- Shipping Height
- 54.8 cm
- Shipping Weight
- 16 kg
