Dell Optiplex 7450 AIO Core i5-7500 8GB 500GB 23.8" Win 10 Pro
Quicklinx: CQZ3WS00 Mfr#: 912Y1
  • Core i5
  • IEEE 802.11n
Premier 23.8" business All-in-One desktop with the greatest level of manageability and security. Featuring optional 4K resolution and touch display.
Elegant and efficient: The stunningly expansive 23.8" UHD 4K resolution WLED display, also available in FHD (1920x1080) resolution, makes it easy to present, share and display more onscreen information to reduce scrolling and improve productivity.
Feel the difference: Optional multi-point touch screen allows you to interact with your work, so you can have a more hands on approach to success.
Created for collaboration: Engineered with integrated speakers, a dual array microphone, and an HD web camera, along with Microsoft Skype for Business certification, the 7450 delivers collaboration and communication capabilities for both video and telephone conferencing.
Power your success: Equipped with up to 7th and 6th Gen Intel processors for comprehensive Operating System support.
Work remotely, with confidence: Optional Intel Standard Manageability technology allows for remote out of band management capabilities for increased uptime and productivity.
Upgraded everywhere: With up to 32GB of DDR4 memory, a variety of storage solutions, including high performance solid state drives, and optional next generation AMD discrete graphics, the 7450 All-in-One delivers unrivaled performance.
Less clutter, more versatility: This flexible AIO offers multiple wireless options, while streamlining all connections to one single plug for a cleaner and more functional workspace.
More control, more comfort: Articulating and Height Adjustable stand options allow you to alter the position your monitor for optimal comfort and productivity.
Stay connected with ease: Multiple port options improve the way you work by creating an easy and centralized way to connect and share from your devices.
Optional Bluetooth and 802.12ac 2x2 wireless LAN enable you to work without wires.
Packed with eight USB ports, including a USB 3.0 Type C and a side USB 3.0 with PowerShare, for fast data transfers and the ability to conveniently charge other devices even while the system is powered down.
Standard Media Card Reader SD4.0 allows for fast data transfer from a variety of memory cards.
Multiple ways to display: DisplayPort & HDMI ports provide modern digital connectivity for multi-display usage so you can view more information on screen without minimize or closing applications.
Easy access: With a tool-less design, the 7450 All-in-One is easy to maintain and upgrade, maximizing return on investment.
  • Elegant and efficient
    The stunningly expansive 4K resolution WLED display, makes it easy to present, share and display more onscreen information to reduce scrolling and improve productivity.
  • Created for collaboration
    Engineered with integrated speakers, a dual array microphone, and an HD web camera, the 7450 delivers collaboration and communication capabilities for both video and telephone conferencing.
  • Less clutter, more versatility
  • Multiple ways to display
  • Easy access
Dell OptiPlex 7450 - all-in-one - Core i5 7500 3.4 GHz - vPro - 8 GB - HDD 500 GB - LED 23"
Personal computer - all-in-one
Platform Technology
Intel vPro Platform
Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA - 7200 rpm
Optical Storage
DVD-Writer
Monitor
23" - LED - 1920 x 1080 (Full HD)
Graphics Controller
Intel HD Graphics 630
Camera
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Microsoft Office (Trial)
57.524 cm x 6.279 cm x 39.29 cm
9.76 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 3 years - response time: next business day
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
All-in-one - with height-adjustable stand
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel Q170
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 16 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD-Writer
Monitor
Monitor Type
LED
Diagonal Size
23"
Native Resolution
Widescreen Display
Monitor Features
Anti-glare
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
2 Megapixel
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Mouse
Optical
USB
Audio Input
Two microphones
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Bays
2 internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 2 M.2 Card
5 x USB 3.0 (4 rear) , 2 x USB 2.0 (2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.0 (PowerShare) , 1 x HDMI input , 1 x HDMI output , 1 x DisplayPort , 1 x audio line-out , 1 x headphones/microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Pricing Type
Power supply
Power Provided
155 Watt
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
57.524 cm
6.279 cm
39.29 cm
9.76 kg
35 °C
20 - 80% (non-condensing)
