Dell Optiplex 7050 MFF Core i5-7500T 8GB 256GB SSD Win 10 Pro
Quicklinx: CQYWWS00 Mfr#: 12WHD
  • Core i5
  • IEEE 802.11n
Small footprint micro desktop with Intel vPro Technology delivers full-size desktop performance and features versatile mounting options.
Stay flexible: With full-power features in an incredibly condensed design, the OptiPlex 7050 lets you maximize your work environment. The new Micro All-in-One stand and multiple mounting options create versatile, flexible solutions to any office situation. Stands and mounts sold separately.
Easy access: With a tool-less design and a simple removable side panel, you have easy access to key system components such as drives and memory so your system can be easily upgraded, remaining viable for years to come.
Mount it and forget it: The New OptiPlex Micro DVD/RW Enclosure lets you secure your micro PC directly on a wall or under a desk - with the added performance of a DVD/RW drive, so you can watch and share data easily with system, while the Micro stays out of sight.
Power your success: Intel 7th Gen processors up to Core i7 run the fastest OptiPlex yet with 32GB 2400MHz DDR4 memory support for 2400MHz memory, while supporting 35W and 65W processors matching all the performance of much larger desktops.
Multi-monitor support: Up to 3 monitors can be connected to the 7050 Micro with the purchase of an additional video port.
Smooth, speedy performance: Advanced PCIe and NVMe drives provides insanely fast boot and data access times.
Expect fewer wires and faster meetings with instant conferencing and collaboration anyone can access with a wireless network. Create a secure and manageable meeting space with OptiPlex 7050 Micro enabled with Intel Unite software for better communication among teams, including real-time sharing, annotation and file transfers. Users can connect, share and display with a split-screen view. With the ability to mark-up shared content and even drag and drop files with ease. Available on select configurations.
Work remotely, with confidence: Optional Intel vPro technology allows for remote and advanced out of band management capabilities for increased productivity and lower risk.
A partner you can trust: MTBF Certified & MIL SPEC tested, the OptiPlex 7050 delivers the reliability and consistency your work demands.
End-to-end protection: Dell's advanced Endpoint Security Suite offers comprehensive threat protection from end-to-end, all centrally managed so your data and devices stay secure.
  • Stay flexible
    With full-power features in an incredibly condensed design, the OptiPlex 7050 lets you maximize your work environment. The Micro All-in-One stand and multiple mounting options create versatile, flexible solutions to any office situation.
  • Easy access
  • Mount it and forget it
    The OptiPlex Micro DVD/RW enclosure lets you secure your micro PC directly on a wall or under a desk - with the added performance of a DVD/RW drive, so you can watch and share data easily with system, while the Micro stays out of sight.
  • Smooth, speedy performance
    Advanced PCIe and NVMe drives provide insanely fast boot and data access times.
Dell OptiPlex 7050 - micro - Core i5 7500T 2.7 GHz - vPro - 8 GB - SSD 256 GB
Personal computer - micro
Platform Technology
Intel vPro Platform
Intel Core i5 (7th Gen) 7500T / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - PCI Express - M.2
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Microsoft Office (Trial)
3.556 cm x 17.78 cm x 18.288 cm
1.18 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 3 years - response time: next business day
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
Micro
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2
1 x 256 GB
Interface Type
PCI Express
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI, DisplayPort
Audio Output
High Definition Audio
Ethernet Controller
Intel I219-V
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Remote Wake Up, PXE support
Bays
1 (total) / 0 (free) x internal 2.5" / 3.5" shared
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 2 (total) / 0 (free) x M.2 Card
4 x USB 3.1 Gen 1 , 1 x USB-C (1 in front) , 1 x USB 3.1 Gen 1 (1 in front) (PowerShare) , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x DisplayPort , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Pricing Type
Power supply
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
3.556 cm
17.78 cm
18.288 cm
1.18 kg
35 °C
10 - 90% (non-condensing)
