Product
Dell OptiPlex 7040 SFF Intel Core i7-6700 8GB 500GB Windows 7 Professional
Quicklinx: C16TWS00 Mfr#: 7040-4104
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
Built-in wireless technology with the long-range 802.11ac wireless technology makes it easy to surf, stream and stay connected. Watch your family's favorite DVDs or install software easily using the built-in optical drive.
Enjoy enhanced audio from integrated performance speakers expertly tuned by Waves MaxxAudio Pro. Meet compliance regulations right out of the box and protect data on any device with Dell Data Protection Encryption.
  • Small is mighty
    Powered by the 6th generation Intel Core processors.
  • Multitask smoothly
    The DDR4 memory is coupled with PCIe solid-state drives.
  • Support for three displays
    DisplayPort and HDMI connectivity for greater visibility of your tasks, even across multiple applications.
  • Expanded capabilities
    Designed to support dual hard drives and expandable discrete graphics, to grow with your needs.
  • You hold the keys
    Dell Client Command Suite free tools allow flexible and automated BIOS or system configurations for your desktop fleet.
  • Serves organizations of all sizes
    Dell KACE System Management solutions available to meet demanding IT management needs.
  • Touchable décor
    Easily interact on the edge-to-edge touch screen for a completely immersive experience ideal for gaming or video editing.
  • Expand your digital library
    A 1 TB hard disk drive provides plenty of storage for your family's photos, music and digital files, so you can continually capture, save and share new memories.
  • Settle in to movie night
  • Superior sound
  • Centralized remote management
  • Secure credential storage
    FIPS 140-2-certified TPM and Dell ControlVault add extra layers of hardware security by isolating user passwords and credentials on a separately controlled hardware chip.
  • Stop advanced malware
    Dell Data Protection Protected Workspace launches apps in a virtualized container and restores a safe environment in only 20 seconds.
Dell OptiPlex 7040 - SFF - Core i7 6700 3.4 GHz - 8 GB - 500 GB
Personal computer - small form factor
Platform Technology
Intel vPro Technology
1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (4 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 530
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence
29.2 cm x 9.26 cm x 29 cm
4.48 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - response time: next business day
Platform Technology
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q170 Express
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe x16 - low-profile , 1 (total) / 1 (free) x PCIe x4 - low-profile , 1 M.2 Card
4 x USB 2.0 (2 front, 2 rear) , 6 x USB 3.0 (2 front, 4 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x HDMI , 2 x DisplayPort
RoHS, WEEE, E-Standby, CEL, BFR, China RoHS
Pricing Type
Power supply
Power Provided
180 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
Microsoft Office (Trial)
ENERGY STAR Certified
ENERGY STAR Version
6.0
29.2 cm
9.26 cm
29 cm
4.48 kg
C16T C2G 2m USB 2.0 A/B Cable - Black In Stock £3.87
C16T C2G HDMI to DisplayPort Adapter Converter In Stock £37.46
C16T C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.65
C16T C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.72
C16T C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
C16T C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.32
C16T C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.20
C16T C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.75
C16T C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.89
