21.5'' narrow-bezel all-in-one desktop with Full HD and customized deployment options for a smart workspace.
Efficiency in every inch
Witness crystal clear clarity from every pixel with a 21.5" narrow-bezel Full HD IPS display (1920x1080). -
Unconstrained team work
Experience faster collaboration with integrated speakers, a dual array microphone, and a Full HD pop-up camera. Perfect for call centers, kiosks and educational environments that benefit from video and telephone conference capabilities. -
Rich connectivity options
Numerous port options create a smart and unified way to connect and share from your devices. Bluetooth 5 and 802.12ac 2x2 wireless LAN enables you to work without wires. A side-mounted USB-C 3.1 Gen2 port allows easy access and speedy data transfer along with a USB PowerShare that keeps your peripherals charged even while the system is off. And with multiple USB ports and a DisplayPort, you can view more information on screen without minimizing or closing applications.
- Dell OptiPlex 5270 All In One - all-in-one - Core i5 9500 3 GHz - 8 GB - HDD 500 GB - LED 21.5"
- Personal computer - all-in-one
- Bundled Services
- 3 Years Basic Onsite
- Processor
- Intel Core i5 (9th Gen) 9500 / 3 GHz (4.4 GHz) (6-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA - 7200 rpm
- Optical Storage
- No optical drive
- Card Reader
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD) @ 60 Hz
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Networking
- GigE, 802.11a, 802.11b/g/n, 802.11ac Wave 2, Bluetooth 5.0
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 49.8 cm x 5.45 cm x 32.9 cm
- 5.33 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Bundled Services
- Product Form Factor
- All-in-one - with height-adjustable stand
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 21.5"
- Native Resolution
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen Display
- Horizontal Viewing Angle
- 89
- Vertical Viewing Angle
- 89
- Pixel Pitch
- 0.2745 mm
- Response Time
- 25 ms
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel
- Resolution
- Full HD
- Pop up camera, 74.9 degrees
Input Device
- Keyboard (on selected markets only)
Keyboard
- Keyboard Name
- Dell KB216 Wired Keyboard
- Interface
- USB
Audio Input
- Array microphone
- Ethernet Controller
- Intel I219-V
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- Remote Wake Up, PXE support, MU-MIMO Support
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- Bays
- Internal 2.5"
- Slots
- M.2 Card
- 2 x USB 2.0 (2 rear) (Power on/Wake-up support) , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 Gen 1 (PowerShare) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x USB-C 3.1 Gen 2 , 1 x DisplayPort , 1 x audio line-out (1 rear) , 1 x headphones/microphone
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Pricing Type
- Power supply
- Voltage Required
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
- Software
- Microsoft Office (Trial)
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.1
- Dimensions & Weight Details
- 49.8 cm - 5.45 cm - 32.9 cm - 5.33 kg - without stand , 25.64 cm - 22.5 cm - 3.01 kg - stand
- 49.8 cm
- 5.45 cm
- 32.9 cm
- 5.33 kg
- Shipping Width
- 79.8 cm
- Shipping Depth
- 19.2 cm
- Shipping Height
- 48.6 cm
- Shipping Weight
- 12.4 kg
