All the features, all in one place: Dell OptiPlex 5260 is a 21.5" narrow bezel all-in-one desktop with Full HD and advanced manageability and security features.
Stunning from every angle
Witness crystal-clear clarity from every pixel with a 21.5" narrow bezel Full HD IPS display (1920x1080). -
Designed for team work
Experience superb collaboration with integrated speakers, a dual array microphone, and a Full HD pop-up camera. Perfect for call centers, kiosks and educational environments that benefit from video and telephone conference capabilities. -
Multiple ways to plug-in
Numerous port options create an easy and centralized way to connect and share from your devices. Bluetooth 5.0 and 802.11ac 2x2 wireless LAN enables you to work without wires. A side mounted USB-C for easy access and speedy data transfer. A USB PowerShare keeps your peripherals charged even while the system is off. The Standard Media Card Reader SD4.0 transfers data quickly from a variety of memory cards. And with multiple USB ports and a DisplayPort, you can view more information on screen without minimizing or closing applications. -
Easy access
With a simple removable rear panel and easy access to key system components, the 5260 All-in-One is easy to maintain and upgrade, maximizing return on investment.
- Dell OptiPlex 5260 All In One - all-in-one - Core i5 8500 3 GHz - 8 GB - 256 GB - LED 21.5"
- Personal computer - all-in-one
- Processor
- 1 x Intel Core i5 (8th Gen) 8500 / 3 GHz (4.1 GHz) (6-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA
- Hard Drive
- 1 x SSD 256 GB - SATA - M.2
- Optical Storage
- DVD-Writer
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD)
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Networking
- GigE, 802.11a, 802.11b/g/n, 802.11ac Wave 2, Bluetooth 5.0
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Black
- 49.8 cm x 5.45 cm x 32.9 cm
- 5.74 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - response time: next business day
- Personal computer
- Product Form Factor
- All-in-one - with height-adjustable stand
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8500 / 3 GHz
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 256 GB
- Interface Type
- SATA
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 21.5"
- Native Resolution
- Widescreen Display
- Horizontal Viewing Angle
- 89
- Vertical Viewing Angle
- 89
- Pixel Pitch
- 0.2745 mm
- Response Time
- 25 ms
- Image Brightness
- 200 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- 60 Hz refresh rate
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel
- Resolution
- Full HD
- Pop up camera
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
- Keyboard Name
- Dell KB216 Wired Keyboard
- Interface
- USB
Mouse
- Mouse Name
- Dell MS116 USB Optical Mouse
- Technology
- Optical
- Interface
- USB
Audio Input
- Array microphone
- Ethernet Controller
- Intel I219-V
- Wireless LAN Supported
- Wireless NIC
- Intel Wireless-AC 9560
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- MU-MIMO Support
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
- Bays
- Internal 2.5"
- Slots
- M.2 Card
- 5 x USB 2.0 (2 rear) , 2 x USB 2.0 (2 internal) (supports SmartPower On) , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 Gen 1 (PowerShare) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x USB-C 3.1 Gen 2 , 1 x DisplayPort , 1 x audio line-out (1 rear) , 1 x headphones/microphone
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Pricing Type
- Power supply
- Nominal Voltage
- Power Provided
- 155 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
- Software
- Microsoft Office (Trial)
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.1
- 49.8 cm
- 5.45 cm
- 32.9 cm
- 5.74 kg
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.49 | in stock |
£883.41
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£799.42
