Dell Optiplex 5260 21.5" AIO Intel Core i5-8500 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: F95LWS00 Mfr#: J50DW
  • Core i5
  • IEEE 802.11n
All the features, all in one place: Dell OptiPlex 5260 is a 21.5" narrow bezel all-in-one desktop with Full HD and advanced manageability and security features.
  • Stunning from every angle
    Witness crystal-clear clarity from every pixel with a 21.5" narrow bezel Full HD IPS display (1920x1080).
  • Designed for team work
    Experience superb collaboration with integrated speakers, a dual array microphone, and a Full HD pop-up camera. Perfect for call centers, kiosks and educational environments that benefit from video and telephone conference capabilities.
  • Multiple ways to plug-in
    Numerous port options create an easy and centralized way to connect and share from your devices. Bluetooth 5.0 and 802.11ac 2x2 wireless LAN enables you to work without wires. A side mounted USB-C for easy access and speedy data transfer. A USB PowerShare keeps your peripherals charged even while the system is off. The Standard Media Card Reader SD4.0 transfers data quickly from a variety of memory cards. And with multiple USB ports and a DisplayPort, you can view more information on screen without minimizing or closing applications.
  • Easy access
    With a simple removable rear panel and easy access to key system components, the 5260 All-in-One is easy to maintain and upgrade, maximizing return on investment.
Dell OptiPlex 5260 All In One - all-in-one - Core i5 8500 3 GHz - 8 GB - SSD 256 GB - LED 21.5"
Personal computer - all-in-one
Intel Core i5 (8th Gen) 8500 / 3 GHz (4.1 GHz) (6-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
SSD 256 GB - SATA - M.2
Optical Storage
DVD-Writer
Monitor
21.5" - LED - 1920 x 1080 (Full HD) @ 60 Hz
Graphics Controller
Intel UHD Graphics 630
Camera
GigE, 802.11a, 802.11b/g/n, 802.11ac Wave 2, Bluetooth 5.0
OS Provided
Windows 10 Pro 64-bit Edition
49.8 cm x 5.45 cm x 32.9 cm
5.74 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - response time: next business day
Personal computer
Product Form Factor
All-in-one - with height-adjustable stand
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2
1 x 256 GB
Interface Type
SATA
Storage Controller
1 x SATA
Optical Storage
DVD-Writer
Monitor
Monitor Type
LED - IPS
Diagonal Size
21.5"
Native Resolution
V-Sync Rate at Max Res.
60 Hz
Widescreen Display
Horizontal Viewing Angle
89
Vertical Viewing Angle
89
Pixel Pitch
0.2745 mm
Response Time
25 ms
Image Brightness
200 cd/m²
Image Contrast Ratio
1000:1
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
Audio Output
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
2 Megapixel
Resolution
Full HD
Pop up camera
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KB216 Wired Keyboard
USB
Mouse
Mouse Name
Dell MS116 USB Optical Mouse
Optical
USB
Audio Input
Array microphone
Ethernet Controller
Intel I219-V
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
MU-MIMO Support
Bays
Internal 2.5"
Slots
M.2 Card
5 x USB 2.0 (2 rear) , 2 x USB 2.0 (2 internal) (supports SmartPower On) , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 Gen 1 (PowerShare) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x USB-C 3.1 Gen 2 , 1 x DisplayPort , 1 x audio line-out (1 rear) , 1 x headphones/microphone
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Pricing Type
Power supply
Power Provided
155 Watt
80 PLUS Certification
80 PLUS Bronze
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
Microsoft Office (Trial)
ENERGY STAR Certified
ENERGY STAR Version
6.1
49.8 cm
5.45 cm
32.9 cm
5.74 kg
