Mainstream 21.5" business All-in-One desktop with advanced manageability and security features. With multiple stand options to fit the way you work.
Brilliant from every angle: Witness stunning clarity from every pixel with a 21.5" Wide Viewing Angle WLED display with Full HD (1920x1080) resolution.
Feel the difference: The optional ten point multi-touch screen allows you interact with your tasks, so you can pinch, drag, and swipe your way to success.
Created for collaboration: Experience superb collaboration capabilities thanks to integrated speakers, a dual array microphone, and an HD web camera, along with Microsoft Skype for Business certification. Cooperation and communication capabilities for both video and telephone conferencing has never been more seamless.
Power your success: Equipped with up to 7th and 6th Gen Intel processors for comprehensive Operating System support.
Work remotely, with confidence: Optional Intel Standard Manageability technology allows for remote out of band management capabilities for increased productivity and support.
The latest technology: With up to 32GB of DDR4 memory, a variety of storage solutions, including high performance solid state drives, and optional next generation AMD discrete graphics, the 5250 All-in-One delivers a powerful and efficient work experience.
Less clutter, more versatility: This flexible AIO offers multiple wireless options, while streamlining all connections to one single plug for a cleaner and more functional workspace.
Design your workspace: Articulating and Height Adjustable stand options allow you to alter the position your monitor for optimal comfort and productivity.
Stay connected with ease: Multiple port options improve the way you work by creating an easy and centralized way to connect and share from your devices. Optional Bluetooth and 802.12ac 2x2 wireless LAN enable you to work without wires. Packed with Six USB ports, including a side USB 3.0 with PowerShare that conveniently charges other devices even while the system is powered down. Standard Media Card Reader SD4.0 allows for fast data transfer from a variety of memory cards.
Multiple ways to display: DisplayPort and HDMI ports provide modern digital connectivity for multi-display usage so you can view more information on screen without minimizing or closing applications.
Easy access: With a tool-less design, the 5250 All-in-One is easy to maintain and upgrade, maximizing return on investment.
Witness stunning clarity from every pixel with a 21.5" wide viewing angle WLED display with Full HD resolution. -
Experience superb collaboration capabilities thanks to integrated speakers, a dual array microphone, and an HD web camera. Cooperation and communication capabilities for both video and telephone conferencing has never been more seamless. -
Advanced technology
With DDR4 memory, a variety of storage solutions, including high-performance solid state drives, the 5250 All-in-One delivers a powerful and efficient work experience. -
This flexible AIO offers multiple wireless options, while streamlining all connections to one single plug for a cleaner and more functional workspace. -
DisplayPort and HDMI ports provide modern digital connectivity for multi-display usage so you can view more information on screen without minimizing or closing applications. -
Easy access
- Dell OptiPlex 5250 All In One - all-in-one - Core i5 7500 3.4 GHz - 8 GB - HDD 500 GB - LED 21.5"
- Personal computer - all-in-one
- Processor
- Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 4 in 1
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD) - touchscreen
- Graphics Controller
- Intel HD Graphics 630
- Camera
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Microsoft Office (Trial)
- Black
- 57.524 cm x 6.279 cm x 39.29 cm
- 11 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 3 years - response time: next business day
- Personal computer
- Product Form Factor
- All-in-one - with height-adjustable stand
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q170
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer
Card Reader
- 4 in 1 card reader
Monitor
- Monitor Type
- LED
- Touchscreen
- Diagonal Size
- 21.5"
- Native Resolution
- Widescreen Display
Graphics Controller
- Graphics Processor
Audio Output
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
Mouse
- Technology
- Optical
- Interface
- USB
Audio Input
- Two microphones
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Bays
- 2 (total) / 1 (free) x internal 2.5" x 1/8H
- Slots
- 2 M.2 Card
- 5 x USB 3.0 (4 rear) , 2 x USB 2.0 (2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.0 (PowerShare) , 1 x HDMI input , 1 x HDMI output , 1 x DisplayPort , 1 x audio line-out , 1 x headphones/microphone
- Pricing Type
- Power supply
- Voltage Required
- Power Provided
- 155 Watt
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
- Software
- 57.524 cm
- 6.279 cm
- 39.29 cm
- 11 kg
- 0 °C
- 35 °C
- 20 - 80% (non-condensing)
