Dell Optiplex 5050 MFF Core i5-7500T 8GB 500GB Windows 10 Pro
Quicklinx: CQYBWS00 Mfr#: C346V
  • Core i5
  • IEEE 802.11n
High-performance, ultracompact business desktop with advanced security and manageability.
  • Stay flexible
    With full-power features in an incredibly condensed design, the OptiPlex 5050 lets you maximize your work environment. The Micro All-in-One stand and multiple mounting options create versatile, flexible solutions to any office situation.
  • Mount it and forget it
    The OptiPlex Micro DVD/RW Enclosure lets you secure your micro PC directly on a wall or under a desk - with the added performance of a DVD/RW drive, so you can watch and share data easily with system, while the Micro stays out of sight.
  • Easy access
    With a tool-less design and a simple removable side panel, you have easy access to key system components such as drives and memory so your system can stay up to date for longer, remaining viable for years to come.
Dell OptiPlex 5050 - micro - Core i5 7500T 2.7 GHz - 8 GB - 500 GB
Personal computer - micro
1 x Intel Core i5 (7th Gen) 7500T / 2.7 GHz (3.3 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max) DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
Windows 10 Pro 64-bit Edition
17.8 cm x 3.6 cm x 18.2 cm
1.18 kg
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - response time: next business day
Personal computer
Product Form Factor
Micro
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KB216 Wired Keyboard
USB
Mouse
Optical
USB
Ethernet Controller
Intel I219-V
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Remote Wake Up, PXE support
Bays
1 (total) / 0 (free) x internal 2.5" x 1/8H
Slots
2 (total) / 2 (free) x M.2 Card
4 x USB 3.1 Gen 1 (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 in front) , 1 x HDMI , 1 x DisplayPort , 1 x USB 3.1 Gen 1 (PowerShare) , 1 x VGA
Pricing Type
Build To Plan (BTP)
Power adapter
Nominal Voltage
Power Provided
65 Watt
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
Microsoft Office (Trial)
17.8 cm
3.6 cm
18.2 cm
1.18 kg
35 °C
10 - 90% (non-condensing)
