Dell OPTIPLEX 3060 MFF I5-8500T 4GB 500Gb Windows 10 Pro
Quicklinx: F16FWS00 Mfr#: GTKGH
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 500GB, 500GB
Storage Type: HDD
  • Core i5
More than 50 in stock
£396.67 ex VAT
£476.00 inc VAT
Standard delivery Delivered within 3-5 working days
Ultracompact business desktop with versatile mounting options for a customized workspace.
  • Compact without compromise
    With full-power features in a space-saving design, more workers choose the OptiPlex micro than ever before. The micro takes up less surface area while still maintaining all the reliability you've come to expect.
  • Mount it and forget it
    With exclusive custom mounting options, the micro adapts to your unique environment, giving you the freedom to work how you want.
  • Power is a priority
    With a powerful processor, every task is a breeze.
  • Stronger signal
    Improve wireless performance with the 802.11ac Wave 2 Wi-Fi. Stay connected at a greater distance from your router and deliver top Wi-Fi speeds for faster streaming.
  • Seamless connectivity
    Work confidently with smooth connectivity thanks to plenty of port options, including DisplayPort, HDMI, VGA or serial port.
Dell OptiPlex 3060 - micro - Core i5 8500T 2.1 GHz - 4 GB - 500 GB
Personal computer - micro
1 x Intel Core i5 (8th Gen) 8500T / 2.1 GHz (3.5 GHz) (6-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 630
GigE
OS Provided
3.6 cm x 17.8 cm x 18.2 cm
1.18 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
TCO Certified Desktops 5
Limited warranty - 1 year - response time: next business day
Personal computer
Product Form Factor
Micro
Built-in Devices
Speaker
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel H370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Speakers Included
1 x mixed channel
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Mouse
Mouse Name
Dell MS116 USB Optical Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111HSD-CG
Bays
Internal 2.5"
Slots
1 (total) / 1 (free) x M.2 Card - 2280/2230 , 1 (total) / 1 (free) x M.2 Card - 2230
4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 in front) , 1 x HDMI , 1 x DisplayPort , 2 x USB 2.0
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
Pricing Type
Power adapter
Power Provided
65 Watt
TCO Certification
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
Microsoft Office (Trial)
TCO Certified
3.6 cm
17.8 cm
18.2 cm
1.18 kg
Shipping Width
23.8 cm
Shipping Depth
49.8 cm
Shipping Height
13.3 cm
Dell OPTIPLEX 3060 MFF I5-8500T 4GB 500Gb Windows 10 Pro Bundle deal on Dell OPTIPLEX 3060 MFF I5-8500T 4GB 500Gb Windows 10 Pro
£576.25
saving £2.42
£495.84
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F16F 041089
Condition: This item is new and unused. It does not come in its original packaging.
This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £332.75
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Storage Type: HDD
Processor Model: I5-8500T
Type: Personal computer
Case Style: Ultra small form factor
Optical Storage: None
Brand: Dell
Stock Status: Used Stock
Price Range Ex VAT: 300 - 500
