Dell Optiplex 3050 SFF Core i5-7500 8GB 128GB SSD Win 10 Pro
Quicklinx: CQXXWS00 Mfr#: G7HYR
  • Core i5
Compact and space-saving desktops with flexibility for dual orientation, expandability options and multiple display support.
Mighty powerful: Powered by 6th generation Intel Core processors.
Support for two displays: DisplayPort, HDMI and optional VGA connectivity allows greater visibility of your tasks.
Plenty of memory: Up to 16GB of DDR3 memory technology.
World's most manageable: IT can manipulate BIOS settings and configure systems with ample flexibility that organizational IT infrastructures require.
You hold the keys: Dell Client Command Suite free tools allow flexible and automated BIOS or system configurations for your desktop fleet.
Packaged to perform: Factory installed with Dell Command , Update automatically presents updates.
Serves organizations of all sizes: Dell KACE System Management solutions available to meet demanding IT management needs.
The world's most secure desktops are armed with Dell Data Protection hardware and software along with additional optional features.
Centralized remote management: Meet compliance regulations right out of the box and protect data on any device with Dell Data Protection , Encryption.
Authentication options: Ensure only authorized users have access to your data with FIPS 201-certified smart card, fingerprint readers or contact-less smart card reader.
Secure credential storage: FIPS 140-2-certified TPM and Dell ControlVault add extra layers of hardware security by isolating user passwords and credentials on a separately controlled hardware chip.
Stop advanced malware: Dell Data Protection , Protected Workspace launches apps in a virtualized container and restores a safe environment in only 20 seconds.
Single console security: Dell Data Protection , Endpoint Security Suite offers comprehensive threat protection, authentication and access management, and encryption, all centrally managed.
  • Work unimpeded
    These desktops come with all the same reliability and space saving benefits you've come to expect without sacrificing power or performance.
  • Take back your workspace
    Custom designed cable covers reduce clutter and match the chassis for a more efficient and visually appealing work space.
  • Service with ease
    Tool-less entry for serviceability and in-band management enables accessible system maintenance so you can you easily upgrade and replace components.
Dell OptiPlex 3050 - SFF - Core i5 7500 3.4 GHz - 8 GB - SSD 128 GB
Personal computer - small form factor
Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630
1GbE
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Microsoft Office (Trial)
9.271 cm x 29.21 cm x 29.006 cm
5.14 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year - response time: next business day , Switzerland: limited warranty - 3 years - response time: next business day
Personal computer
Product Form Factor
Small form factor
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel B250
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
SSD
1 x 128 GB
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
IEEE 802.3
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 internal 2x2.5" / 1x3.5" shared
Slots
1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1 , 1 M.2 Card
4 x USB 3.1 Gen 1 (2 front, 2 rear) , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 rear) , 1 x HDMI , 1 x DisplayPort , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Pricing Type
Power supply
Power Provided
180 Watt
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
9.271 cm
29.21 cm
29.006 cm
5.14 kg
35 °C
10 - 90% (non-condensing)
