Compact and space-saving desktops with flexibility for dual orientation, expandability options and multiple display support.
Mighty powerful: Powered by 6th generation Intel Core processors.
Support for two displays: DisplayPort, HDMI and optional VGA connectivity allows greater visibility of your tasks.
Plenty of memory: Up to 16GB of DDR3 memory technology.
World's most manageable: IT can manipulate BIOS settings and configure systems with ample flexibility that organizational IT infrastructures require.
You hold the keys: Dell Client Command Suite free tools allow flexible and automated BIOS or system configurations for your desktop fleet.
Packaged to perform: Factory installed with Dell Command , Update automatically presents updates.
Serves organizations of all sizes: Dell KACE System Management solutions available to meet demanding IT management needs.
The world's most secure desktops are armed with Dell Data Protection hardware and software along with additional optional features.
Centralized remote management: Meet compliance regulations right out of the box and protect data on any device with Dell Data Protection , Encryption.
Authentication options: Ensure only authorized users have access to your data with FIPS 201-certified smart card, fingerprint readers or contact-less smart card reader.
Secure credential storage: FIPS 140-2-certified TPM and Dell ControlVault add extra layers of hardware security by isolating user passwords and credentials on a separately controlled hardware chip.
Stop advanced malware: Dell Data Protection , Protected Workspace launches apps in a virtualized container and restores a safe environment in only 20 seconds.
Single console security: Dell Data Protection , Endpoint Security Suite offers comprehensive threat protection, authentication and access management, and encryption, all centrally managed.
Work unimpeded
These desktops come with all the same reliability and space saving benefits you've come to expect without sacrificing power or performance. -
Take back your workspace
Custom designed cable covers reduce clutter and match the chassis for a more efficient and visually appealing work space. -
Service with ease
Tool-less entry for serviceability and in-band management enables accessible system maintenance so you can you easily upgrade and replace components.
- Dell OptiPlex 3050 - SFF - Core i5 7500 3.4 GHz - 4 GB - HDD 500 GB
- Personal computer - small form factor
- Processor
- Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 630
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Microsoft Office (Trial)
- Black
- 9.271 cm x 29.21 cm x 29.006 cm
- 5.14 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 1 year - response time: next business day
- Personal computer
- Product Form Factor
- Small form factor
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Black
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel B250
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI, DisplayPort
Audio Output
- High Definition Audio
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
- Keyboard Name
- Dell KB216 Wired Keyboard
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- IEEE 802.3
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2x2.5" / 1x3.5" shared
- Slots
- 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1 , 1 M.2 Card
- 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 rear) , 1 x HDMI , 1 x DisplayPort , 1 x VGA
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Pricing Type
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
- Software
- 9.271 cm
- 29.21 cm
- 29.006 cm
- 5.14 kg
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
