Dell OptiPlex 3050 MFF i3-7100T 4GB 128SSD WIFI W10P
Quicklinx: D4K0WS00 Mfr#: MFXX8
  • Core i3
  • IEEE 802.11n
Ultra compact business desktop with multiple mounting options to best fit your workspace. Offers essential best-in-class security and manageability. Innovative design: With several custom designed mounting solutions, including the New OptiPlex Micro All-in-one Stand with cable cover, you can free yourself from desktop clutter, maxing out on your productivity potential in a visually appealing work space set up. Compact without compromise: Native support for dual display and designed to pack business-class performance into the smallest possible format. Now utilizing 60% less surface area while still maintaining all the reliability you've come to expect. Secure and seamless: Work confidently with unhindered data transfers and smooth connectivity with plenty of port options, including DisplayPort, HDMI, and optional VGA or serial port.
  • Innovative design
    With several custom designed mounting solutions, including the OptiPlex Micro All-in-one stand with cable cover, you can free yourself from desktop clutter, maxing out on your productivity potential in a visually appealing work space set up.
  • Compact without compromise
    Native support for dual display and designed to pack business-class performance into small format. Now utilizing less surface area while still maintaining all the reliability you've come to expect.
  • Service with ease
    Tool-less serviceability and in-band management enables accessible system maintenance so you can more easily upgrade and replace components.
  • Stronger signal
    Improve wireless performance with the advanced 802.11ac Wave 2 Wi-Fi. Stay connected at a greater distance from your Wi-Fi router and deliver top Wi-Fi speeds for faster streaming.
  • Secure and seamless
    Work confidently with unhindered data transfers and smooth connectivity with plenty of port options, including DisplayPort, HDMI.
Dell OptiPlex 3050 - micro - Core i3 7100T 3.4 GHz - 4 GB - 128 GB
Personal computer - micro
1 x Intel Core i3 (7th Gen) 7100T / 3.4 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
1 x SSD 128 GB
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
Windows 10 Pro 64-bit Edition
3.6 cm x 17.8 cm x 18.2 cm
1.18 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - response time: next business day
Personal computer
Product Form Factor
Micro
Embedded Security
Trusted Platform Module (TPM) Security Chip
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B250 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD
1 x 128 GB
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI, DisplayPort
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KB216 Wired Keyboard
USB
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111H
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 3165
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Bays
1 internal 2.5" x 1/8H
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 M.2 Card - 2230 , 1 M.2 Card - 2280/2242
4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 in front) , 1 x HDMI , 1 x DisplayPort , 2 x USB 2.0 , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, CEL, China RoHS
Pricing Type
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
Microsoft Office (Trial)
ENERGY STAR Certified
3.6 cm
17.8 cm
18.2 cm
1.18 kg
