Dell OptiPlex 3050 MFF Core i5-7500T 4GB 500GB Windows 10 Pro
Quicklinx: CQY5WS00 Mfr#: 9C7XK
  • Core i5
Ultracompact, energy efficient desktop with versatile deployment and custom mounting options.
Powerfully efficient: Powered by 6th generation Intel Core processors.
Multitask smoothly: Up to 16GB of DDR3 memory for seamless workflow across multiple apps.
Support for two displays DisplayPort, HDMI and optional VGA connectivity allows greater visibility of your tasks.
World's most manageable: Manipulate BIOS settings and configure systems with ample flexibility that organizational IT infrastructures require.
You hold the keys: Dell Client Command Suite free tools allow flexible and automated BIOS or system configurations for your desktop fleet.
Packaged to perform: Receive automatic update notifications from factory-installed Dell Command | Update.
Serves organizations of all sizes: Dell KACE System Management solutions available to meet demanding IT management needs.
The world's most secure desktops are armed with Dell Data Protection hardware and software along with additional optional features.
Centralized remote management: Meet compliance regulations right out of the box and protect data on any device with Dell Data Protection | Encryption.
Authentication options: Ensure only authorized users have access to your data with FIPS 201-certified smart card, fingerprint readers or contact-less smart card reader.
Secure credential storage: FIPS 140-2-certified TPM and Dell ControlVault add extra layers of hardware security by isolating user passwords and credentials on a separately controlled hardware chip.
Stop advanced malware: Dell Data Protection | Protected Workspace launches apps in a virtualized container and restores a safe environment in only 20 seconds.
Single console security: Dell Data Protection | Endpoint Security Suite offers comprehensive threat protection, authentication and access management, and encryption, all centrally managed.
  • Work unimpeded
    These desktops come with all the same reliability and space saving benefits you've come to expect without sacrificing power or performance.
  • Take back your workspace
    Custom designed cable covers reduce clutter and match the chassis for a more efficient and visually appealing work space.
  • Service with ease
    Tool-less entry for serviceability and in-band management enables accessible system maintenance so you can you easily upgrade and replace components.
Dell OptiPlex 3050 - micro - Core i5 7500T 2.7 GHz - 4 GB - 500 GB
Personal computer - micro
1 x Intel Core i5 (7th Gen) 7500T / 2.7 GHz (3.3 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630
GigE
OS Provided
Windows 10 Pro 64-bit Edition
17.8 cm x 3.6 cm x 18.2 cm
1.17 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - response time: next business day
Personal computer
Product Form Factor
Micro
Embedded Security
Trusted Platform Module (TPM) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel B250 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI, DisplayPort
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Keyboard
Keyboard Name
Dell KB216 Wired Keyboard
USB
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111H
Bays
1 (total) / 0 (free) x internal 2.5" x 1/8H
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card
4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 in front) , 1 x HDMI , 1 x DisplayPort , 2 x USB 2.0 (2 rear) , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, CECP
Pricing Type
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition Multilingual User Interface (MUI)
Software
Microsoft Office (Trial)
ENERGY STAR Certified
ENERGY STAR Version
6.0
17.8 cm
3.6 cm
18.2 cm
1.17 kg
