Free your workspace from clutter with the OptiPlex 3030 All-in-One desktop. Essential features and reliable tools make this all-in-one a versatile fit for your office environment. The OptiPlex 3030 All-in-one provides the perfect solution for information kiosks, check-in services, digital signage and collaboration tools. Perform the highest productivity with powerful processors and enhance perfect graphics performance. The OptiPlex 3030 All-in-One is thin, space saving and meets the practical and performance needs of working and educational settings. With a port cover that locks cables in place, this desktop keeps you focused on the task at hand.
LCD clarity
LCD screen offers high resolution and edge-to-edge glass for a vibrant view. You can simply navigate between applications and windows. Built-in VESA mounting capability allows you to put your OptiPlex 3030 All-in-one on the wall, saving desk space. -
Keep your data protected
Comprehensive security and encryption solutions keep your data protected from your desktop, to external media to the cloud. Manage data-encryption centrally across devices without disrupting end users or existing IT processes with Dell Data Protection. Tighten security with advanced authentication options and leading-edge malware prevention. Stay in control of access to systems and information with Dell Data Protection tools for single sign-on and authentication management. Trusted Platform Module (TPM) grants an additional layer of data protection and secure credential storage. -
Protect your investment
Physically secure your system with a K-Lock and lockable port cover. -
Share effectively
Data transfers are quick and responsive with high-speed USB 3.0 support. Share presentations with a VGA port for easy connections to compatible external monitors and projectors. -
Connect with clarity
Collaborate face to face with an HD 720p webcam and communicate clearly across your network with a digital microphone and built-in speakers. -
Effortless management
A complete suite of time-saving management tools are available on your OptiPlex 3030 All-in-one. Rely on Dell Services to configure, deploy, manage and support Dell OptiPlex desktops for their entire lifecycle, including reselling or recycling when they reach end of life. With in-band management solutions, updates are seamless and intuitive. -
Essential tools
Avoid downtime and eliminate guesswork with Dell automated tools and utilities for deploying, monitoring and updating systems efficiently. Best-in-class integration offers efficient, centralized and automated management helping you save time and money.
- Dell OptiPlex 3030 - all-in-one - Core i5 4590S 3 GHz - 4 GB - HDD 500 GB - LED 19.5"
- Personal computer - all-in-one - Intel Anti-Theft Technology (iAT), Intel Identity Protection Technology (Intel IPT), Setup Password, Intel Trusted Execution Technology (Intel TXT)
- Processor
- Intel Core i5 (4th Gen) 4590S / 3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC
- Hard Drive
- HDD 500 GB
- Optical Storage
- DVD-Writer
- Card Reader
- 4 in 1
- Monitor
- 19.5" - LED - 1600 x 900 (HD+)
- Graphics Controller
- Intel HD Graphics 4600
- Audio Output
- Integrated
- Networking
- GigE, Bluetooth, Wi-Fi
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro 64-bit Licence
- Software Included
- Windows 8.1 Pro 64-bit (DVD)
- 48.9 cm x 6.7 cm x 3.28 cm
- 6.33 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - response time: next business day
- Personal computer
- Product Form Factor
- All-in-one
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
Storage Controller
- 1 integrated
Optical Storage
- DVD-Writer
Card Reader
- 4 in 1 card reader
Monitor
- Monitor Type
- LED
- Diagonal Size
- 19.5"
- Native Resolution
- 1600 x 900 (HD+)
- Widescreen Display
- Monitor Features
- Anti-glare
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA
Audio Output
- Integrated
Camera
- Form Factor
- Integrated
- Resolution (MP)
- 0.92 Megapixel
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
Audio Input
- Microphone
- Ethernet Controller
- Realtek RTL8151GD
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, Wi-Fi
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 PCIe Half Mini Card , 1 (total) / 0 (free) x CPU
- 2 x USB 3.0 , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x headphones/microphone , 1 x audio line-out
- Theft/Intrusion Protection
- RoHS, WEEE, CECP, China RoHS
- Power supply
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- 48.9 cm
- 6.7 cm
- 3.28 cm
- 6.33 kg
Jabra BIZ 2300 Mono USB Headset | In Stock | £103.88 |
Jabra BIZ 2300 Duo USB Headset | In Stock | £116.07 |
