Dell Optiplex 3030 19.5" AIO Intel Core i5-4590s 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: B86HWS00 Mfr#: 3030-8178
  • Microsoft Windows 7 Professional 64-bit Edition
  • Core i5
Free your workspace from clutter with the OptiPlex 3030 All-in-One desktop. Essential features and reliable tools make this all-in-one a versatile fit for your office environment. The OptiPlex 3030 All-in-one provides the perfect solution for information kiosks, check-in services, digital signage and collaboration tools. Perform the highest productivity with powerful processors and enhance perfect graphics performance. The OptiPlex 3030 All-in-One is thin, space saving and meets the practical and performance needs of working and educational settings. With a port cover that locks cables in place, this desktop keeps you focused on the task at hand.
  • LCD clarity
    LCD screen offers high resolution and edge-to-edge glass for a vibrant view. You can simply navigate between applications and windows. Built-in VESA mounting capability allows you to put your OptiPlex 3030 All-in-one on the wall, saving desk space.
  • Keep your data protected
    Comprehensive security and encryption solutions keep your data protected from your desktop, to external media to the cloud. Manage data-encryption centrally across devices without disrupting end users or existing IT processes with Dell Data Protection. Tighten security with advanced authentication options and leading-edge malware prevention. Stay in control of access to systems and information with Dell Data Protection tools for single sign-on and authentication management. Trusted Platform Module (TPM) grants an additional layer of data protection and secure credential storage.
  • Protect your investment
    Physically secure your system with a K-Lock and lockable port cover.
  • Share effectively
    Data transfers are quick and responsive with high-speed USB 3.0 support. Share presentations with a VGA port for easy connections to compatible external monitors and projectors.
  • Connect with clarity
    Collaborate face to face with an HD 720p webcam and communicate clearly across your network with a digital microphone and built-in speakers.
  • Effortless management
    A complete suite of time-saving management tools are available on your OptiPlex 3030 All-in-one. Rely on Dell Services to configure, deploy, manage and support Dell OptiPlex desktops for their entire lifecycle, including reselling or recycling when they reach end of life. With in-band management solutions, updates are seamless and intuitive.
  • Essential tools
    Avoid downtime and eliminate guesswork with Dell automated tools and utilities for deploying, monitoring and updating systems efficiently. Best-in-class integration offers efficient, centralized and automated management helping you save time and money.
Dell OptiPlex 3030 - all-in-one - Core i5 4590S 3 GHz - 4 GB - HDD 500 GB - LED 19.5"
Personal computer - all-in-one - Intel Anti-Theft Technology (iAT), Intel Identity Protection Technology (Intel IPT), Setup Password, Intel Trusted Execution Technology (Intel TXT)
Intel Core i5 (4th Gen) 4590S / 3 GHz (, up to 3.7 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC
Hard Drive
HDD 500 GB
Optical Storage
DVD-Writer
Card Reader
4 in 1
Monitor
19.5" - LED - 1600 x 900 (HD+)
Graphics Controller
Intel HD Graphics 4600
Audio Output
Integrated
GigE, Bluetooth, Wi-Fi
OS Provided
Microsoft Windows 7 Professional 64-bit Edition + Windows 8.1 Pro 64-bit Licence
Software Included
Windows 8.1 Pro 64-bit (DVD)
48.9 cm x 6.7 cm x 3.28 cm
6.33 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - response time: next business day
Personal computer
Product Form Factor
All-in-one
Processor / Chipset
CPU
Clock Speed
3 GHz
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel H81
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Storage Controller
1 integrated
Optical Storage
DVD-Writer
Card Reader
4 in 1 card reader
Monitor
Monitor Type
LED
Diagonal Size
19.5"
Native Resolution
1600 x 900 (HD+)
Widescreen Display
Monitor Features
Anti-glare
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA
Audio Output
Integrated
Camera
Integrated
Resolution (MP)
0.92 Megapixel
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Audio Input
Microphone
Ethernet Controller
Realtek RTL8151GD
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, Wi-Fi
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 PCIe Half Mini Card , 1 (total) / 0 (free) x CPU
2 x USB 3.0 , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x headphones/microphone , 1 x audio line-out
Theft/Intrusion Protection
RoHS, WEEE, CECP, China RoHS
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
85%
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
48.9 cm
6.7 cm
3.28 cm
6.33 kg
B86H Jabra BIZ 2300 Mono USB Headset In Stock £103.88
B86H Jabra BIZ 2300 Duo USB Headset In Stock £116.07
