Dell Networking N2024 Switch 24 ports Managed Rack-Mountable
Quicklinx: BNXSWS00 Mfr#: 210-ABNV
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
£1,170.72 ex VAT
£1,404.86 inc VAT
N-series is a family of energy-efficient and cost-effective 1GbE and 10GbE switches designed for modernizing and scaling network infrastructure. Built to help keep operating costs down, the N2000 series can operate at temperatures up to 122 °F (50 °C) to help reduce cooling costs.
  • Upgrade your network
  • Designed for efficiency
  • Advanced feature set to simplify management
    The Dell Networking N2000 series is designed for easy deployment, outstanding interoperability and a low learning curve for network administrators.
  • Deploy with confidence at any scale
    With high throughput and capacity to handle unexpected workloads, the N2000 series switches are ideal solutions for fast growing GbE networks that require high-density aggregation with seamless redundancy and availability.
Dell Networking N2024 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 172 Gbps , Forwarding performance: 128 Mpps , Stacking bandwidth: 84 Gbps
Virtual interfaces (VLANs): 4096 , ARP entries: 1024 , NDP entries: 400 , Priority queues per port: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , IPv4 routes (dynamic): 256 , VLAN routing interfaces: 256 , ACL: 100 , Max ACL rules system-wide: 2048 , Maximum rules per ACL: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 1024 , Maximum ACL rules per interface (IPv4) egress rules: 512 , Maximum ACL rules per interface (IPv6) ingress rules: 512 , Maximum ACL rules per interface (IPv6) egress rules: 256 , Maximum VLAN interfaces with ACLs applied: 24 , Maximum aggregation groups: 128 , Maximum dynamic ports per switch stack: 144 , Maximum member ports per LAG: 8
MAC Address Table Size
8192 entries
Routing Protocol
RIP-1, RIP-2, static IPv4 routing, static IPv6 routing
Remote Management Protocol
Telnet, TFTP
Flow control, auto-negotiation, VLAN support, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Access Control List (ACL) support, IPv4 support, Energy Efficient Ethernet, Management Information Base (MIB), dual firmware images, Neighbor Discovery Protocol (NDP), redundant fans
44 cm x 25.7 cm x 4.35 cm
3.69 kg
Enclosure Type
Subtype
Gigabit Ethernet
Ports
Performance
8192 entries
Routing Protocol
Telnet, TFTP
Encryption Algorithm
MD5, AES, SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
24 x Gigabit LAN RJ-45 , 2 x 10Gbit LAN SFP+ , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
Internal power supply
Installed Qty
1
Power Provided
100 Watt
42.9 Watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Included
FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, VCCI Class A, EAC, CCC Class A
44 cm
25.7 cm
4.35 cm
3.69 kg
Limited warranty - lifetime
45 °C
0 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Humidity Range Storage
0 - 85%
BNXS C2G 2m USB 2.0 A/B Cable - Black In Stock £3.36
BNXS C2G 5m USB 2.0 A/B Cable - Black In Stock £4.62
BNXS C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.74
BNXS C2G USB Superbooster Extender Kit In Stock £32.19
BNXS Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase In Stock £133.06
BNXS Dell SFP (mini-GBIC) transceiver module GigE 1000Base-SX In Stock £74.34
Ports: 24
Managed: Yes
Brand: Dell
Price Range Ex VAT: £1000 - £1500
