The N4000 switch series offers a power-efficient and resilient 10 Gigabit Ethernet (10GbE) switching solution with support for 40GbE uplinks for advanced Layer 3 distribution for offices and campus networks. The N4000 switch series has high-performance capabilities and wire-speed performance utilizing a non-blocking architecture to easily handle unexpected traffic loads. The N4000 series includes dual internal hot-swappable 80PLUS-certified power supplies for high availability and power efficiency. The switches offer simple management and scalability via flexible user port stacking at 10 Gbps or 40 Gbps. The high-availability stacking architecture allows management of up to 12 switches from a single IP address.
Modernize campus network architectures
Modernize campus network architectures with a power-efficient and resilient 10/40GbE switching solution for environments requiring high throughput and availability at the aggregation or core. For greater interoperability in multivendor networks, all N-series switches offer the latest open-standard protocols and include technology to interface with Cisco protocol RPVST+ and devices using CDP. Achieve high availability and full bandwidth utilization with Multi-chassis Link Aggregation (MLAG). All N-series switches support MLAG to create active/active loop-free redundancy without spanning tree. Server rooms can deliver reliable server and storage connectivity with features to help save time and avoid configuration errors. These high density 48-port 10GbE switches are ready for converged fabric requirements for SAN and LAN networks with loss-less operation for iSCSI environments with Data Center Bridging (DCB). The N4000 series is also fully tested and validated to work with Dell EqualLogic PS-series storage arrays. -
Leverage familiar tools and practices
All N-series switches include Dell Networking OS 6 designed for easier deployment, greater interoperability and a lower learning curve for network administrators. One common command line interface (CLI) and GUI using a well-known command language gets skilled network administrators productive quickly. This allows network administrators to maintain consistent configurations by running one OS release across all N-Series products. With USB auto-configuration, network administrators can rapidly deploy mirrored configurations to numerous devices by simply inserting a USB key. -
Deploy with confidence at any scale
N4000 series switches help create performance assurance with a data rate up to 1.28 Tbps (full duplex) and a forwarding rate up to 952 Mpps. Scale easily with 10/40 Gbps user port stacking supporting distances up to 100 meters. Switch stacks of up to 672 10GbE ports can be managed from a single screen using the highly-available stacking architecture for high-density aggregation with seamless redundant availability.
- Dell Networking N4032 - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x 10GBase-T
- Performance
- Switching fabric bandwidth: 640 Gbps , Forwarding performance: 476 Mpps
- Capacity
- MAC addresses: 131072 , IPv4 routes (static): 1024 , IPv6 routes (static): 1024 , IPv4 routes (dynamic): 8160 , IPv6 routes (dynamic): 4096 , Maximum member ports per LAG: 8 , Maximum dynamic ports per switch stack: 144 , LAG groups: 128 , Priority queues per port: 8 , OSPF routes: 8160 , RIP routes: 512 , ECMP next hops per route: 4 , ECMP groups: 1024 , VLAN routing interfaces: 128 , VLANs supported: 4094 , Multicast entries (IPv4): 512 , Multicast entries (IPv6): 256 , ARP entries: 6144 , NDP entries: 400 , ACL: 100 , Maximum rules per ACL: 1023 , Max ACL rules system-wide: 3072 , Maximum ACL rules per interface (IPv4) egress rules: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 2047 , Maximum ACL rules per interface (IPv6) egress rules: 512 , Maximum ACL rules per interface (IPv6) ingress rules: 1021 , Maximum VLAN interfaces with ACLs applied: 24
- MAC Address Table Size
- 131072 entries
- Routing Protocol
- OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 2, SNMP, RMON, HTTP, SSH
- Layer 3 switching, Layer 2 switching, MDI/MDI-X switch, auto-negotiation, port mirroring, stackable, Broadcast Storm Control, IP address filtering, Access Control List (ACL) support, Quality of Service (QoS), Dynamic ARP Inspection (DAI), LLDP support, Remote Switch Port Analyzer (RSPAN), Management Information Base (MIB), dual firmware images, redundant fans, MAC and IP-based ACLs support, Time-controlled ACLs support, Protocol-based VLANs support
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, ANSI/TIA-1057, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az, IEEE 802.1Qbb, IEEE 802.1Qaz
- Power Redundancy
- 43.383 cm x 45.999 cm x 43.43 cm
- 9.83 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- 24 x 10GBase-T
- Performance
- Capacity
- 131072 entries
- Routing Protocol
- Encryption Algorithm
- AES, SSL, TLS 1.0
- Authentication Method
- RADIUS, TACACS+, LDAP
- RAM
- 2 GB
- Flash Memory
- 256 MB
- 24 x 10GBase-T RJ-45 , 1 x Gigabit LAN RJ-45 management , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A management
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Provided
- 460 Watt
- 176 Watt
- FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, EAC, CCC Class A
- 43.383 cm
- 45.999 cm
- 43.43 cm
- 9.83 kg
- Limited warranty - parts - lifetime
- 0 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
