Dell Networking N3024 are an energy-efficient and cost-effective switches designed for modernizing and scaling network infrastructure. N3024 switches utilize a comprehensive enterprise-class Layer 2 and Layer 3 feature set, deliver consistent, simplified management and offer high-availability device and network design. The N3024 switches offer a power-efficient and resilient Gigabit Ethernet (GbE) switching solution with integrated 10GbE uplinks for advanced Layer 3 distribution for offices and campus networks. The N3024 switches have high-performance capabilities and wire-speed performance utilizing a non-blocking architecture to easily handle unexpected traffic loads. Use dual internal hot-swappable 80PLUS-certified power supplies for high availability and power efficiency. The switches offer simple management and scalability via an 84Gbps (full-duplex) high availability stacking architecture that allows management of up to 12 switches from a single IP address.
Deliver clean power to network devices with PoE+ support
The Dell Networking N3024 has 24 ports of Power-over-Ethernet Plus (PoE+) without an external power supply. This allows you to attach devices with high power requirements without running a separate power cable. PoE+ is particularly useful in older buildings where installing power to multiple, widespread locations can be prohibitively expensive. -
Designed for efficiency
Built to help keep operating costs down, the N3024 can operate at temperatures up to 113°F (45°C) to help reduce cooling costs. Features designed to improve overall efficiency. -
Advanced feature set to simplify management
The Dell Networking N3024 switch is designed for easy deployment, outstanding interoperability and a low learning curve for network administrators. A single OS release allows you to maintain consistent configurations across all N-Series products with a comprehensive feature set. -
Deploy with confidence at any scale
With high throughput and capacity to handle unexpected workloads, the N3024 switches are ideal Layer 3 solutions for fast growing GbE networks that require high-density aggregation with seamless redundancy and availability.
- Dell Networking N3024 - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 2 x 10 Gigabit SFP+ + 2 x combo Gigabit SFP
- Performance
- Switching fabric bandwidth: 212 Gbps , Forwarding performance: 158 Mbps , Stacking bandwidth: 84 Gbps
- Capacity
- MAC addresses: 16384 , Static routes: 1024 , OSPF routes: 8160 , RIP routes: 512 , Virtual interfaces (VLANs): 128 , IPv4 routes (Multicast): 1536 , IPv6 routes (Multicast): 512 , ARP entries: 6144 , NDP entries: 400 , ACL entries: 100 , ACL rules: 4096
- MAC Address Table Size
- 16K entries
- Routing Protocol
- OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 2, SNMP, RMON, HTTP, SSH
- Flow control, Layer 3 switching, Layer 2 switching, MDI/MDI-X switch, auto-negotiation, VLAN support, port mirroring, stackable, WRR queuing, Broadcast Storm Control, STP support, RSTP support, MSTP support, ACL support, QoS, port forwarding, STP Root Guard, LLDP support, LACP, Energy Efficient Ethernet, dual firmware images, NAC, tagged VLAN, GVRP
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power Redundancy
- Optional
- 43.4 cm x 40.7 cm x 4.35 cm
- 6 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- Routing Protocol
- Encryption Algorithm
- MD5, AES, SSL, TLS
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 1 GB
- Flash Memory
- 256 MB
- 24 x Gigabit LAN RJ-45 , 2 x 10Gbit LAN SFP+ , 2 x Gigabit LAN SFP , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
- Expansion Slots
- 1 (total) / 1 (free) x Expansion Slot
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Provided
- 200 Watt
- 52.8 Watt
- 43.4 cm
- 40.7 cm
- 4.35 cm
- 6 kg
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 0 - 95%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 65 °C
- Humidity Range Storage
- 0 - 85%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
