Dell N2048 Switch L2+ Managed 48 x 10/100/1000
Quicklinx: BTPCWS00 Mfr#: 210-ABNX
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
Hurry, only 2 left in stock!
£1,266.56 ex VAT
£1,519.87 inc VAT
N-series is a family of energy-efficient and cost-effective 1GbE and 10GbE switches designed for modernizing and scaling network infrastructure. Built to help keep operating costs down, the N2000 series can operate at temperatures up to 113 °F (45 °C) to help reduce cooling costs.
Dell Networking N2048 - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L2+ - Managed - stackable
Enclosure Type
Front to back airflow rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 220 Gbps , Forwarding performance: 164 Mpps , Stacking bandwidth: 84 Gbps
Virtual interfaces (VLANs): 4096 , ARP entries: 1024 , NDP entries: 400 , Priority queues per port: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , IPv4 routes (dynamic): 256 , VLAN routing interfaces: 256 , ACL: 100 , Max ACL rules system-wide: 2048 , Maximum rules per ACL: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 1024 , Maximum ACL rules per interface (IPv4) egress rules: 512 , Maximum ACL rules per interface (IPv6) ingress rules: 512 , Maximum ACL rules per interface (IPv6) egress rules: 256 , Maximum VLAN interfaces with ACLs applied: 24 , Maximum aggregation groups: 128 , Maximum dynamic ports per switch stack: 144 , Maximum member ports per LAG: 8
MAC Address Table Size
8192 entries
Routing Protocol
RIP-1, RIP-2, static IPv4 routing, static IPv6 routing
Remote Management Protocol
Telnet, TFTP
Flow control, auto-negotiation, VLAN support, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Access Control List (ACL) support, IPv4 support, Energy Efficient Ethernet, Management Information Base (MIB), dual firmware images, Neighbor Discovery Protocol (NDP), redundant fans
44 cm x 25.7 cm x 4.35 cm
4.05 kg
Enclosure Type
Subtype
Gigabit Ethernet
Ports
Performance
8192 entries
Routing Protocol
Telnet, TFTP
Encryption Algorithm
MD5, AES, SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
48 x Gigabit LAN RJ-45 , 2 x 10Gbit LAN SFP+ , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
Internal power supply
Installed Qty
1
Power Provided
100 Watt
53.9 Watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Included
FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, VCCI Class A, EAC, CCC Class A
44 cm
25.7 cm
4.35 cm
4.05 kg
Limited warranty - lifetime
45 °C
0 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Humidity Range Storage
0 - 85%
BTPC C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.18
Ports: 48
Managed: Yes
Brand: Dell
Price Range Ex VAT: 1000 - 1500
