Adapter converts Mini DisplayPort to VGA
The Dell Mini DisplayPort to VGA Adapter lets you view video content from any desktop or laptop with Mini DisplayPort video output on a variety of VGA-compliant displays. Compliant with DisplayPort specifications version 1.1a and supporting a maximum resolution of 1920 x 1200 pixels, this versatile adapter ensures a quality viewing experience on everything from monitors to projectors.
Display mobile content on the big screen
This adapter allows you to take video content from your desktop or laptop and display it on any monitor, projector or HDTV featuring VGA input. As long as your device is equipped with a mini DisplayPort output, this compact adapter ensures seamless conversion. Use it to enjoy movies on a home projector, mirror your desktop for an expanded workstation or show presentations at school or work.
Enjoy crystal-clear video
The adapter is compliant with DisplayPort specification version 1.1a, ensuring true DisplayPort quality when video content is adapted and viewed. DisplayPort 1.1a specifications allow there to be a longer reach between source and display without reducing picture quality.
This adapter allows you to take video content from your desktop or laptop and display it on any monitor, projector or HDTV featuring VGA input. As long as your device is equipped with a mini DisplayPort output, this compact adapter ensures seamless conversion. Use it to enjoy movies on a home projector, mirror your desktop for an expanded workstation or show presentations at school or work. -
The Dell Mini DisplayPort to VGA adapter supports resolution of up to 1920 x 1200 pixels to provide crisp, rich video. -
Compact size offers easy portability
Measuring 8 x 2 x 1 inches (L x W x H), this plug-and-play adapter is small enough to keep on hand for impromptu presentations for clients or movie nights with friends. The adapter is fitted with a 20-pin Mini DisplayPort on one end and a 15-pin HDI5 VGA on the other, a standard fit for a wide variety of VGA-compatible display monitors, projectors and HDTVs. -
DisplayPort-compliant for optimum picture quality
- Dell Mini DisplayPort to VGA Adapter - video adapter - Mini DisplayPort to HD-15 (VGA) - 20.32 cm
- Video adapter
- 1200p support
- Length
- 20.32 cm
- Connector
- Mini DisplayPort - male (input)
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - female (output)
- DisplayPort 1.1a
- 1-year warranty
- Designed For
- Inspiron 5559; Latitude 3340, E7240, E7270, E7440, E7470; Precision 7510, 7520, 7710, 7720, 7750, M3800, T1700; Venue 8 Pro; Vostro 3558, 3559; XPS 12, 12 9250, 13, 13 9350, 14, 15, 15 9550, 17
- Video adapter
- 1200p support
- Length
- 20.32 cm
- 5.08 cm
- 2.54 cm
- Connector
- DisplayPort 1.1a
- 1-year warranty
- Designed For
- Dell Inspiron 5559 , Dell Latitude 3340, E7240, E7270, E7440, E7470 , Dell Precision 7510, 7520, 7710, 7720, 7750, M3800, T1700 , Dell Venue 8 Pro (5855) , Dell Vostro 3558, 3559 , Dell XPS 12, 12 9250, 13 (9333), 13 (9343), 13 9350, 14 (L401X), 14 (L421X), 15 (9530), 15 (L501X), 15 (L502X), 15 (L521X), 15 9550, 17 (L701X), 17 (L702X)
