Product
Dell MDS14 Dual Monitor Stand
Quicklinx: 92PSWS00 Mfr#: 482-10011
The Dell MDS14 Dual Monitor Stand is designed to maximize your viewing comfort and improve your productivity with its multi-adjustment capabilities such as tilt, swivel, height adjust and horizontally slide the monitors on the stand. It can easily snap on two Dell monitor panels with VESA support and enjoy improved productivity and a clutter-free desktop. Its U-shaped monitor stand also frees up productive desk space in front of the monitors and reduces cable clutter with a cable management slot on the stand riser. The two adaptors provided on the stand, assured that the dual monitor stand can attach to any VESA compliant monitor.
  • Customize dual monitor alignment for comfort and productivity
    The Dell dual monitor stand lets you easily customize the positioning and alignment of two monitors, so you can achieve your preferred setup for optimal comfort. The stand provides height, tilt and swivel adjustments for two monitors of same or various sizes. It allows for the two monitors to slide laterally, ensuring they are always on the same plane.
  • Eliminate clutter and reclaim your workspace
    Replacing two monitor stands with just one saves space, especially with the Dell dual monitor stand's smartly designed U-shaped base. Use the space directly in front of you for writing, referencing materials and other tasks. The stand also features integrated cable management hidden within a slot in the stand riser. Neatly stow away your cables and cords through the slot for a less cluttered and more comfortable work area.
Dell MDS14 Dual Monitor Stand - stand
Stand
Tilt
-5° to 20°
Pan
-15° to 15°
Lift
11 cm
Adjustments
Pan, tilt
Recommended Use
2 monitors
Recommended Display Size
24"
Flat Panel Mount Interface
Max Load Weight
6.5 kg
Package Content
2 x VESA monitor mounts
3 years warranty
Dell E1916, E2016, E2216, E2316, E2416, P2016, P2212, P2213, P2214, P2415; Latitude 14, E5250, E5270, E5440, E5450, E5550, E7270; OptiPlex 3020, 9020; Precision Mobile Workstation 3510, 5510, 7510, 7710; Precision Tower 3620, 5810, 7810, 7910; UltraSharp U2415, U2417, U2515, UZ2315
Package Content
AV Furniture
Stand
Recommended Use
2 monitors
24"
Tilt
-5° to 20°
Pan
-15° to 15°
Lift
11 cm
Adjustments
Pan, tilt
Max Load Weight
6.5 kg
Min Load Weight
3 kg
Limited warranty - 3 years
Dell E170S, E1713S, E1909W, E190S, E1911, E1912H, E1913, E1913S, E1914H, E1916H, E2009W, E2011H, E2013H, E2014H, E2016, E2210, E2211H, E2213, E2213H, E2214H, E2216h, E2311H, E2313H, E2314H, E2316H, E2414H, E2416H, P2011H, P2012H, P2014H, P2016, P2210, P2210H, P2211H, P2212H, P2213, P2214H, P2311H, P2312H, P2314H, P2314T, P2411H, P2412H, P2414H, P2415Q , Dell Latitude 14 Rugged Extreme (7404), E5250, E5270, E5440, E5450, E5540, E5550, E7270 , Dell OptiPlex 3020 (micro), 9020 (micro) , Dell Precision Mobile Workstation 3510, 5510, 7510, 7710 , Dell Precision Tower 3620, 5810, 7810, 7910 , Dell Professional P170S, P190S, P1911, P1913, P1913S, P1914S, P2714T , Dell UltraSharp 1908FP, 1909W, 2007FP, 2009W, 2408WFP, U2211H, U2212HM, U2311H, U2312HM, U2410, U2412M, U2413, U2414H, U2415, U2417HJ, U2515H, UP2414Q, UZ2215H, UZ2315H
