Your basket is empty
Dell Mains Battery Pack 48WHr
Quicklinx: BQXDWS00 Mfr#: 451-11947
Lithium-ion battery is longer lived than conventional batteries and does not require replacement as often. This 6-cell lithium-ion battery from Dell helps you power up your system for business trips and vacations. With a capacity of 48 WHr this battery lets you work seamlessly when you are on the move.
Dell Primary Battery - laptop battery - Li-Ion - 48 Wh
Laptop battery
Lithium Ion 6-cell - 48 Wh
Batteries Qty
1
Inspiron 15R, 17R, 17R-5720; Vostro 3460, 3560
Laptop battery
Quantity
1
6-cell Lithium Ion
48 Wh
Dell Inspiron 15R, 17R, 17R-5720 , Dell Vostro 3460, 3560
