Always on the go? No more worries about running out of battery power! You can power your system with this 6-cell lithium-ion battery from Dell. The battery lets you work seamlessly when you are on the move for business trips or vacations. This battery provides uninterrupted reliable performance you need to get the most out of your system.
- Dell - laptop battery - Li-Ion - 48 Wh
- Laptop battery
- Battery
- Lithium Ion 6-cell - 48 Wh
- Designed For
- Inspiron 15 N5040, M4110, M5040, M5110
- Laptop battery
- Technology
- 6-cell Lithium Ion
- Capacity
- 48 Wh
- Designed For
- Dell Inspiron 15 N5040, M4110, M5040, M5110
