Dell M115HD WXGA 450 Lumens LED Projector
Quicklinx: 9HW1WS00 Mfr#: 210-ABOI
Dazzle your audience in the conference room and beyond with the palm-sized, multimedia Dell Mobile Projector M115HD with bright LED technology.
  • The conference room in your laptop bag
    Take your presentations wherever you choose with the Dell Mobile Projector M115HD, the ideal travel companion for the mobile professional.
  • Small and bright
    You want the ultimate in brightness from your projector. Light up the room with the M115HD, featuring dazzlingly bright, colorful and crystal-clear projection.
  • Total connectivity
    Accept no limits when it comes to bringing media to your presentations. The M115HD features a remarkable amount of connectivity, giving you a wide range of media options to choose from. More than just a projector, the M115HD is truly a portable media hub for home and office.
Dell Mobile Projector M115HD - DLP projector
DLP projector - 720p
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
450 ANSI lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED
Bulb life cycle
Up to 30000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
Video Input
RGB
Supported Memory Cards
microSD
Storage Capacity
1 GB Flash
Video Modes
480p, 720p, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
52 Watt
10.53 cm x 10.4 cm x 3.65 cm
360 g
1-year warranty
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
450 ANSI lumens
Contrast Ratio
10000:1
Image Size
76 cm - 203 cm
Projection Distance
0.97 m - 2.58 m
Throw Ratio
1.5:1
Uniformity
80 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
LED
Bulb life cycle
Controls & Adjustments
Keystone correction
High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, MobiShow technology, Mercury-free illumination technology, upgradable firmware
Lens
Focus Type
Manual
Lens Aperture
F/2.0
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI
Video Modes
microSD
Media Player
Storage Capacity
1 GB Flash
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Expansion Slots
1 x microSD
1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x VGA - 24 pin universal I/O , 1 x VGA (on supplied cable)
Carrying case
1 x VGA cable
Security Features
52 Watt
Power Consumption Stand by
0.5 Watt
10.53 cm
10.4 cm
3.65 cm
360 g
Limited warranty - lamp - 1 year , Limited warranty - 1 year
5 °C
35 °C
0 - 80%
Sound Emission
36 dBA
32 dBA
