The docking connector for most of the Latitude E series systems is towards the middle of the system's backend. But, for specific Latitude notebooks, the docking connector is located towards the edge of the backend of the system. Docking spacer is required to dock your system in the right position.
- Dell E-Docking Spacer - docking station adapter
- Product Type
- Docking station adapter
- 19.81 cm x 6.935 cm x 1.636 cm
- Designed For
- E-Port Simple Port Replicator II, Simple Replicator II; Latitude E5250, E5270, E5450, E5470, E5550, E5570, E7240, E7250, E7270, E7440, E7450, E7470; Precision 3510, 7710
- Product Type
- 19.81 cm
- 6.935 cm
- 1.636 cm
- Designed For
- Dell E-Port Simple Port Replicator II, Simple Replicator II , Dell Latitude E5250, E5270, E5450, E5470, E5550, E5570, E7240, E7250, E7270, E7440, E7450, E7470 , Dell Precision 3510, 7710
