Dell Latitude 9510 2in1 Intel Core i5-10210U 8GB 256GB SSD 15" Touch Windows 10 Professional 64-bit
Quicklinx: FW4HWS00 Mfr#: DMTJC
Display Size: 15in
Processor Model: I5-10210U
Operating System: Windows 10 Pro 64-bit Edition
Hard Drive Capacity: 256GB
Optical Storage: None
  • Core i5
  • IEEE 802.11n
£1,414.31 ex VAT
£1,697.17 inc VAT
UK/BTP/Lati 9510/Core i5-10210U/8GB/256GB SSD/2in1 15.0" FHD Touch/Intel UHD/ThBlt & FgrPr & SmtCd/Cam & Mic/WLAN + BT/Backlit Kb/4 Cell/W10Pro/3Y Basic Onsite.
  • Small size, big impact
    The Latitude 9510 is as sleek as it is portable, as Dell smallest and lightest 15" business PC, starting at a mere 1.4 kg (3.1 lb). Dell stretched the 15.0" InfinityEdge screen to the edge to provide maximum work area without the weight.
  • Stunning from the start
    Dell's most premium Latitude ever is meticulously crafted with CNC aluminum, having the finest details of diamond cut edges and a hair-line brushed finish. The new keyboard and touchpad feels as good as it looks.
  • Work wherever
    Corning Gorilla Glass DX on the 2-in-1 offers premium glass innovation for up to 9% reduction in reflections, so you can work anywhere your job takes you. The screen is more durable with up to 15X better scratch resistance and is nearly 2X less susceptible to cracks compared to Gorilla Glass 5. Super Low Power Panel helps save battery while the optional camera shutter increases privacy.
  • Stay cool under pressure
    IT can now manage thermals within the BIOS. It's not tied to software, which saves on storage size and allows IT to focus on other critical software. Carbon blade fans are used for quieter cooling, so you can focus on your work. Additionally, two pipes are better than one for removing heat, and 2-in-1s have an adaptive thermal response, so they stay cooler on your lap than when on a desk.
  • The commitment to sustainability
    Low VOC waterborne paint is used on 100% of painted parts which aims to create a healthier work environment. To help with the fight against pollution, 100% of 2-in-1 packaging trays are recyclable, comprised of ocean-bound plastics (25%) and HDPE recycled plastic (75%). Dell has prevented over 60,000 lbs or 27 metric tons of plastic from ending up in oceans.
Dell Latitude 9510 - 15" - Core i5 10210U - 8 GB RAM - 256 GB SSD
Notebook - flip design
Operating System
Win 10 Pro 64-bit
Intel Core i5 (10th Gen) 10210U / 1.6 GHz (4.2 GHz) / 6 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD - NVMe, Class 35
Optical Drive
No optical drive
Display
15" LED backlight touchscreen 1920 x 1080 / Full HD @ 60 Hz - 147 ppi
Graphics
Intel UHD Graphics
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.1
4-cell
Ambient light sensor, proximity sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip
Grey
34.02 cm x 21.58 cm x 1.399 cm
1.5 kg
Pricing Type
Build To Plan (BTP)
Environmental Standards
TCO Certified Notebooks 8, ENERGY STAR Qualified EPEAT Gold
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe), Class 35
Display
15" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
147
Image Brightness
400 cd/m²
Bezel Type
Flat front
Anti-reflective, 100% sRGB colour gamut, anti-smudge, ±80° horizontal viewing angle, ±80° vertical viewing angle, 35 ms response rate, 0.17 mm pixel pitch
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Resolution
0.9 Megapixel (front)
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
IR camera, RGB camera, 78 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC711-CG
Input
Keyboard, touchpad
Keyboard Backlight
Multi-gesture touch pad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
4-cell lithium polymer
52 Wh
AC Adapter
Input
Output
65 Watt, 5 / 9 / 15 / 20 V, 3.25 A
Connections & Expansion
2 x USB-C 3.2 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery) , USB 3.2 Gen 1 (Power Delivery) , Headphone/microphone combo jack , HDMI
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (30 days trial)
Grey
Integrated Options
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
Pricing Type
Build To Plan (BTP)
1.5 kg
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Display Size: 15in
Graphics: Intel UHD Graphics
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 1000 - 1500
