Dell Latitude 7490 Intel Core i7-8650U 14" 8GB 256GB W10P
Quicklinx: DZ9CWS00 Mfr#: KWT07
Display Size: 14in
Processor Model: I7-8650U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
More than 50 in stock
£1,088.40 ex VAT
£1,306.08 inc VAT
Versatile design. Exceptional experience. The Latitude 7490 is a business-class laptop built with premium materials.
  • Office everywhere
    Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • Premium materials
    The unibody design provides a clean and seamless exterior with superior structural performance.
  • All-day power
    Work confidently with a laptop equipped with all-day battery life and improvements to both web browsing and video playback time.
Dell Latitude 7490 - 14" - Core i7 8650U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8650U / 1.9 GHz (4.2 GHz) / 8 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 2280 SSD
Optical Drive
No optical drive
Display
14" 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
Pointing stick
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
33.1 cm x 22.09 cm x 1.79 cm
1.4 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 3 years - response time: next business day
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Platform Technology
Intel vPro Technology
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz - 2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe
Display
14" - IPS
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare, ±80° horizontal viewing angle, ±80° vertical viewing angle, 157 ppi, 0.161 mm pixel pitch
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Fixed focus
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3246
High Definition Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
4-cell
60 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , USB-C/Thunderbolt 3/DisplayPort , LAN , HDMI , USB 3.1 Gen 1 (PowerShare)
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial)
Case Material
Magnesium alloy
Security
Noise reduction
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2, FIPS 201, TCG Certified
Pricing Type
1.4 kg
35 °C
10 - 90% (non-condensing)
Software applications
Dell Latitude 7490 Intel Core i7-8650U 14 Bundle deal on Dell Latitude 7490 Intel Core i7-8650U 14" 8GB 256GB W10P
£1,276.04
saving £8.33
£1,188.16
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 1000 - 1500
