Dell Latitude 7490 Ci5-8250U 8GB 256GB SSD 13.3" Windows 10 Pro
Quicklinx: DC7VWS00 Mfr#: 8KYRT
  • Core i5
  • IEEE 802.11n
Versatile design. Exceptional experience. The Latitude 7490 is a business-class laptop built with premium materials.
  • Office everywhere
    Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • Premium materials
    The unibody design provides a clean and seamless exterior with superior structural performance.
  • All-day power
    Work confidently with a laptop equipped with all-day battery life and improvements to both web browsing and video playback time.
Dell Latitude 7490 - 14" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Display
14" 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
Pointing stick
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
33.1 cm x 22.09 cm x 1.79 cm
1.4 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 3 years - response time: next business day
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8250U / 1.6 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 2280 SATA
Display
14" - IPS
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Fixed focus
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3246
High Definition Audio
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
4-cell
60 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , USB-C (supports DisplayPort Alt Mode) , LAN , HDMI , USB-C 3.1 Gen 1 (PowerShare)
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Case Material
Magnesium alloy
Security
Noise reduction
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.4 kg
Sustainability Information
TCO Certified
