Dell Latitude 7400 Intel Core i5-8265U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: F957WS00 Mfr#: D4GKY
Display Size: 14in
Processor Model: I5-8265U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£826.96 ex VAT
£992.35 inc VAT
This 14" premium business-class notebook features ExpressConnect, so you can automatically connect to the fastest Wi-Fi signal.
  • Work fast, stay cool
    Dell's fan technology utilizes a liquid crystal polymer material. This allows for the creation of thinner fan blades and provides maximum airflow for an overall cooler experience.
  • Improved screen
    With a 4-sided narrow border panel and antiglare screen, you'll be able to work better in front of the screen wherever you go.
  • Power through the day
    Keep the work flowing with a high-density battery and ExpressCharge, which allows up to 80% charge in one hour.
Dell Latitude 7400 - 14" - Core i5 8265U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
8 GB DDR4
Storage
256 GB SSD
Optical Drive
No optical drive
Display
14" 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
32.135 cm x 21.408 cm x 1.896 cm
1.35 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 3 years - on-site
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
256 GB SSD - (M.2) PCIe
Display
14"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
RGB camera
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3254
High Definition Audio, Wave MAXXAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Multi-gesture touch pad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
4-cell Lithium Ion
60 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , HDMI , Headphone/microphone combo jack , USB-C 3.1 Gen 2/Thunderbolt 3
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Case Material
Carbon fibre
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.35 kg
10 - 90% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Software applications
Dell Latitude 7400 Intel Core i5-8265U 8GB 256GB SSD 14 Bundle deal on Dell Latitude 7400 Intel Core i5-8265U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
£926.13
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Touchscreen: No
Type: Laptop
Brand: Dell
Price Range Ex VAT: 750 - 1000
