This 14" premium business-class notebook features ExpressConnect, so you can automatically connect to the fastest Wi-Fi signal.
Work fast, stay cool
Dell's fan technology utilizes a liquid crystal polymer material. This allows for the creation of thinner fan blades and provides maximum airflow for an overall cooler experience. -
Improved screen
With a 4-sided narrow border panel and antiglare screen, you'll be able to work better in front of the screen wherever you go. -
Power through the day
Keep the work flowing with a high-density battery and ExpressCharge, which allows up to 80% charge in one hour.
- Dell Latitude 7400 - 14" - Core i5 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 256 GB SSD
- Optical Drive
- No optical drive
- Display
- 14" 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Black
- 32.135 cm x 21.408 cm x 1.896 cm
- 1.35 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 3 years - on-site
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD - (M.2) PCIe
Display
- 14"
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- RGB camera
- Sound
- Stereo speakers, array microphone
- Codec
- Realtek ALC3254
- High Definition Audio, Wave MAXXAudio Pro
Input
- Keyboard, touchpad
- Multi-gesture touch pad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Technology
- 4-cell Lithium Ion
- Capacity
- 60 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , HDMI , Headphone/microphone combo jack , USB-C 3.1 Gen 2/Thunderbolt 3
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (Trial)
- Black
- Case Material
- Carbon fibre
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.35 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
Software applications
Bundle includes:
Microsoft Office Home & Business 2019 Box Pack (Medialess, 1 PC, One Time Purchase) worth £191.34 | in stock |
£1,091.71
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£1,007.87
