Dell Latitude 7400 2in1 Core i5-8365U 8GB 256GB SSD win 10 Pro
Quicklinx: FPKHWS00 Mfr#: 344RT
  • Core i5
  • IEEE 802.11n
Set the pace of business with the Latitude 7400 2-in-1, featuring Dell powerful processors in a stunningly small design.
  • Premium inside and out
    The machined aluminum finish and edge-to-edge glass is stunning in any setting and the anti-reflective, anti-smudge coating lets you see your screen in any light.
  • Small and sleek
    The Full HD display maximizes your view, while premium materials impress in any setting.
  • Battery life that runs over multiple workdays
    With hours of battery life, you can stay up to speed for the entire workday and then some.
Dell Latitude 7400 2-in-1 - 14" - Core i5 8365U - vPro - 8 GB RAM - 256 GB SSD
Notebook - flip design
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Platform Technology
Intel vPro Platform
Intel Core i5 (8th Gen) 8365U / 1.6 GHz (4.1 GHz) / 6 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
14" touchscreen 1920 x 1080 / Full HD @ 60 Hz - 157 ppi
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
Silver
31.977 cm x 19.99 cm x 1.489 cm
1.36 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Bundled Services
3 Years Basic Onsite
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
256 GB SSD M.2 PCIe
Display
14"
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
157
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-reflective, anti-smudge, Wide Viewing Angle, 35 ms response rate, ±89° horizontal viewing angle, ±89° vertical viewing angle, 0.161 mm pixel pitch
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Resolution
0.3 Megapixel
Video Resolutions
340 x 340
Frame Rate
30 frames per second
Camera Features
IR camera, 2 x infrared emitters
Sound
Stereo speakers, microphone
Codec
Realtek ALC3254
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - M.2 Card
4-cell lithium polymer
52 Wh
AC Adapter
Input
Output
65 Watt, 20 V, 3.25 A
Connections & Expansion
Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 (PowerShare) , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) (Power Delivery) , HDMI
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Silver
Security
Noise reduction
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
FIPS 140-2, TCG Certified
Pricing Type
1.36 kg
Sustainability Information
ENERGY STAR Certified
Bundled Services
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
105 g
Shock Tolerance (non-operating)
40 g
Vibration Tolerance (operating)
0.26 g @ RMS (random)
Vibration Tolerance (non-operating)
1.37 g @ RMS (random)
FPKH Dell Network Adapter In Stock £15.91
FPKH Dell Slim DW316 USB External DVD Drive In Stock £35.58
FPKH Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £10.93
FPKH Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £15.45
FPKH Dell KB216 Keyboard USB UK QWERTY Grey Inspiron 24 3459 In Stock £13.82
FPKH Dell Multimedia Keyboard KB216 UK In Stock £15.45
FPKH Dell E2020H 20" 1600 x 900 5ms VGA LED monitor In Stock £64.53
