Dell Latitude 7390 Core i5-8250U 8GB 256GB 13.3" Win 10 Pro$
Quicklinx: DYJLWS00 Mfr#: XJ27D
Display Size: 13.3in
Processor Model: I5-8250U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
21 in stock
£733.55 ex VAT
£880.26 inc VAT
Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • Outstanding views
    The gorgeous 13.3" Full HD display is anti-glare and features a narrow border - intelligently engineered to fit a 12" frame for lightweight mobility and a remarkable viewing experience.
  • High-caliber construction
    Built with quality materials like magnesium alloy, the Latitude 7390 combines premium design with high durability.
  • Built to last
    Your laptop can last as long as your tough workday with a long-hour battery life.
  • Advanced technology
    Experience faster data speeds with a PCIe SSD, and higher transfer rates with Thunderbolt 3 connection.
Dell Latitude 7390 - 13.3" - Core i5 8250U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 2280 SSD
Optical Drive
No optical drive
Display
13.3" WLED 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
30.48 cm x 20.795 cm x 1.686 cm
1.17 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 3 years - response time: next business day
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Platform Technology
Intel vPro Technology
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2400 MHz - 2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe
Display
13.3"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare, ±80° horizontal viewing angle, ±80° vertical viewing angle, 166 ppi
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Fixed focus
Sound
Stereo speakers, microphones
Codec
Realtek ALC3246
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
4-cell
60 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , USB-C 3.1 Gen 1/DisplayPort , HDMI , LAN
Memory Card Reader
Yes (microSD)
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2, TCG Certified
Pricing Type
1.17 kg
35 °C
10 - 90% (non-condensing)
Software applications
Dell Latitude 7390 Core i5-8250U 8GB 256GB 13.3 Bundle deal on Dell Latitude 7390 Core i5-8250U 8GB 256GB 13.3" Win 10 Pro$
£918.77
saving £8.33
£832.72
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 500 - 750
