Latitude's superior security,versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity,wherever your job takes you.
Outstanding views
The gorgeous 13.3" Full HD display is anti-glare and features a narrow border - intelligently engineered to fit a 12" frame for lightweight mobility and a remarkable viewing experience. -
High-caliber construction
Built with quality materials like magnesium alloy, the Latitude 7390 combines premium design with high durability. -
Built to last
Your laptop can last as long as your tough workday with a long-hour battery life. -
Advanced technology
Experience faster data speeds with a PCIe SSD, and higher transfer rates with Thunderbolt 3 connection.
- Dell Latitude 7390 - 13.3" - Intel Core i7 - 8650U - vPro - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (8th Gen) - 8650U / 1.9 GHz, up to 4.2 GHz / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 13.3" WLED 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Black
- 30.48 cm x 20.795 cm x 1.686 cm
- 1.17 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 3 years - response time: next business day
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (8th Gen) 8650U / 1.9 GHz
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 SATA
Display
- 13.3"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Fixed focus
- Sound
- Stereo speakers, microphones
- Codec
- Realtek ALC3246
- High Definition Audio
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 60 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 90 Watt
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , USB-C (supports Thunderbolt 3, DisplayPort Alt Mode) , HDMI , LAN
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Black
- Case Material
- Magnesium alloy
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.17 kg
Sustainability Information
- TCO Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
