Dell Latitude 7390 Ci5-8250 2in1 8GB 256GB SSD 13.3" Windows 10 Pro
Quicklinx: DC7TWS00 Mfr#: PDG03
  • Core i5
  • IEEE 802.11n
Latitude's superior security,versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity,wherever your job takes you.
  • Office everywhere
    Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you.
  • An unparalleled viewing experience
    Your 2-in-1 will shine in any professional setting with 13.3 inches of Full HD touch panels with anti-reflective and anti-smudge Corning Gorilla Glass 4. Plus, you'll see more details with fewer interruptions with a narrow bezel designed for greater productivity.
  • Outstanding flexibility
    With tent, laptop, stand and media mode you can view your work from nearly any angle without having to slow down. Multiple display modes, a 2-button touchpad and backlit keyboard provide even more layers of viewing versatility, by letting you see more of your tasks in any light.
  • Log in with one look
    Activate Windows Hello via the infrared camera to facilitate facial recognition for easy and secure access.
  • Built to last
    Your 2-in-1 can last as long as your toughest workday with increased battery life.
  • Fits anywhere
    Your 2-in-1 travels wherever you do. It's thin and light enough to fit in any carrying case that works with your lifestyle, from briefcases to gym bags. Simply grab it and go without being weighed down.
  • Protect your credentials
    The Dell ControlVault 2.0 secure processor provides exceptional authentication capabilities. It stores and protects your passwords, biometric authentication and security codes, so your credentials will be secured no matter where your work takes you.
Dell Latitude 7390 2-in-1 - 13.3" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD
Notebook - flip design
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
13.3" touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
30.51 cm x 21.1 cm x 1.903 cm
1.42 kg
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - response time: next business day
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8250U / 1.6 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Rated Speed
1866 MHz
Storage
Main Storage
256 GB SSD M.2
Display
13.3"
Touchscreen
Yes (10-point multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
255 cd/m²
Anti-reflective, anti-smudge, Corning Gorilla glass 4
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Sound
Stereo speakers, quad array microphone
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Precision touchpad
Communications
Wireless
3-cell lithium polymer
45 Wh
AC Adapter
Input
Output
65 Watt
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , 2 x USB-C (supports DisplayPort Alt Mode) , HDMI
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Security
Noise reduction, ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
FIPS 140-2, TCG Certified
Pricing Type
Build To Plan (BTP)
1.42 kg
Sustainability Information
TCO Certified
