Latitude's superior security,versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity,wherever your job takes you.
Office everywhere
Latitude's superior security, versatility and accessories empower the way you work because your success relies on the ability to maintain office-level productivity, wherever your job takes you. -
An unparalleled viewing experience
Your 2-in-1 will shine in any professional setting with 13.3 inches of Full HD touch panels with anti-reflective and anti-smudge Corning Gorilla Glass 4. Plus, you'll see more details with fewer interruptions with a narrow bezel designed for greater productivity. -
Outstanding flexibility
With tent, laptop, stand and media mode you can view your work from nearly any angle without having to slow down. Multiple display modes, a 2-button touchpad and backlit keyboard provide even more layers of viewing versatility, by letting you see more of your tasks in any light. -
Log in with one look
Activate Windows Hello via the infrared camera to facilitate facial recognition for easy and secure access. -
Built to last
Your 2-in-1 can last as long as your toughest workday with increased battery life. -
Fits anywhere
Your 2-in-1 travels wherever you do. It's thin and light enough to fit in any carrying case that works with your lifestyle, from briefcases to gym bags. Simply grab it and go without being weighed down. -
Protect your credentials
The Dell ControlVault 2.0 secure processor provides exceptional authentication capabilities. It stores and protects your passwords, biometric authentication and security codes, so your credentials will be secured no matter where your work takes you.
- Dell Latitude 7390 2-in-1 - 13.3" - Intel Core i5 - 8250U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 30.51 cm x 21.1 cm x 1.903 cm
- 1.42 kg
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years - response time: next business day
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
- Rated Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD M.2
Display
- 13.3"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 255 cd/m²
- Anti-reflective, anti-smudge, Corning Gorilla glass 4
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Sound
- Stereo speakers, quad array microphone
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
- Precision touchpad
Communications
- Wireless
- Technology
- 3-cell lithium polymer
- Capacity
- 45 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , 2 x USB-C (supports DisplayPort Alt Mode) , HDMI
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Black
- Security
- Noise reduction, ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter
- FIPS 140-2, TCG Certified
- Pricing Type
- 1.42 kg
Sustainability Information
- TCO Certified
