Dell Latitude 7380 Core i5-7300U 8GB 256GB SSD 13.3" Win10 Pro
Quicklinx: D92JWS00 Mfr#: RCTG2
  • Core i5
  • IEEE 802.11n
The gorgeous 13" Full HD display features a narrow border and anti-glare treatment - all intelligently engineered to fit a 12" frame for lightweight mobility and a remarkable viewing experience. Built with high-end materials like Magnesium Alloy, the Latitude 7380 combines premium design with best-in-class durability.
  • Outstanding views
  • High-caliber construction
  • Built to last
    Your laptop can last as long as your toughest workday with a 17-hour battery life, or more than 24 hours with the Dell Power Companion.
  • Leading-edge technology
    Experience faster data speeds with a PCIe SSD, and higher transfer rates with Thunderbolt 3 connection.
  • Premium protection
    Customize your security based on your needs. Choose from Dell's wide range of hardware and software security options including Dell ControlVault 2.0 secure processor, contacted and contactless Smart Card Readers, touch fingerprint reader or infrared camera. Your information is secure no matter where your work takes you.
Dell Latitude 7380 - 13.3" - Intel Core i5 - 7300U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) - 7300U / 2.6 GHz, up to 3.5 GHz / 3 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Display
13.3" 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
30.48 cm x 20.795 cm x 1.995 cm
1.17 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - response time: next business day
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7300U / 2.6 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD M.2 SATA
Display
13.3"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Camera Features
IR camera
Sound
Stereo speakers, microphone
Codec
Realtek ALC3246
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Multi-gesture touch pad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
4-cell
42 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 1.7 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.1 Gen 1 , LAN , USB-C , HDMI , USB 3.1 Gen 1 (PowerShare)
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Security
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.17 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
60 °C
10 - 90% (non-condensing)
