The gorgeous 13" Full HD display features a narrow border and anti-glare treatment - all intelligently engineered to fit a 12" frame for lightweight mobility and a remarkable viewing experience. Built with high-end materials like Magnesium Alloy, the Latitude 7380 combines premium design with best-in-class durability.
Outstanding views
The gorgeous 13" Full HD display features a narrow border and anti-glare treatment - all intelligently engineered to fit a 12" frame for lightweight mobility and a remarkable viewing experience. -
High-caliber construction
Built with high-end materials like Magnesium Alloy, the Latitude 7380 combines premium design with best-in-class durability. -
Built to last
Your laptop can last as long as your toughest workday with a 17-hour battery life, or more than 24 hours with the Dell Power Companion. -
Leading-edge technology
Experience faster data speeds with a PCIe SSD, and higher transfer rates with Thunderbolt 3 connection. -
Premium protection
Customize your security based on your needs. Choose from Dell's wide range of hardware and software security options including Dell ControlVault 2.0 secure processor, contacted and contactless Smart Card Readers, touch fingerprint reader or infrared camera. Your information is secure no matter where your work takes you.
- Dell Latitude 7380 - 13.3" - Intel Core i5 - 7300U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7300U / 2.6 GHz, up to 3.5 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 13.3" 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black
- 30.48 cm x 20.795 cm x 1.995 cm
- 1.17 kg
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - response time: next business day
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7300U / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD M.2 SATA
Display
- 13.3"
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Resolution
- 0.92 Megapixel
- Image Sensor Type
- CMOS
- Camera Features
- IR camera
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC3246
- High Definition Audio
Input
- Keyboard, touchpad
- Multi-gesture touch pad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8265
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 1.7 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.1 Gen 1 , LAN , USB-C , HDMI , USB 3.1 Gen 1 (PowerShare)
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Black
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.17 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 60 °C
- 10 - 90% (non-condensing)
