Elevated design, unparalleled productivity
The world’s smallest 13" premium business-class notebook features ExpressConnect, so you can automatically connect to the fastest Wi-Fi signal.
Stay synced
Thanks to Modern Standby capability, you can resume work quickly when waking your system since Wi-Fi is running in the background. -
Work anywhere
Automatically join the strong Wi-Fi connection with ExpressConnect. Even without Wi-Fi, experience better streaming, downloading, and video conferencing. Stay connected with the 4x4 dynamic antenna tuning solution that provides reliable mobile broadband, especially in weak signal areas. Two extra antennas act as additional "ears", resulting in faster speeds. Dynamic antenna tuning enables global network coverage without needing to switch parts and keeps the laptop small with narrow screen bezels. -
Power through the day
Keep the work flowing with a high-density battery and ExpressCharge, which allows for a fast charge. With Dell Power Manager, you can choose between four modes to balance between optimal battery or power performance. -
Improved performance
The powerful processor increases productivity, manageability, and security for your business. -
Work fast, stay cool
The fan technology utilizes the liquid crystal polymer material. This allows for the creation of thinner fan blades and provides maximum airflow for an overall cooler experience. -
Improved screen
With a four-sided narrow-border panel and anti-glare screen, you'll be able to work better in front of the screen wherever you go.
- Dell Latitude 7300 - 13.3" - Core i5 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 256 GB SSD
- Display
- 13.3" 1920 x 1080 / Full HD @ 60 Hz
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Black
- 30.65 cm x 20.695 cm x 1.845 cm
- 1.24 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 3 years - on-site
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe
Display
- 13.3"
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- RGB camera
- Sound
- Stereo speakers, array microphone
- Codec
- Realtek ALC3254
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
- Multi-gesture touch pad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Technology
- 4-cell Lithium Ion
- Capacity
- 60 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , HDMI , Headphone/microphone combo jack , USB-C 3.1 Gen 2 (supports Thunderbolt)
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (Trial)
- Black
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.24 kg
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
