Dell Latitude 7300 Core i7-8665U 16GB 512GB SSD 13.3" Win 10 Pro
Quicklinx: FP1QWS00 Mfr#: G3TXG
Display Size: 13.3in
Processor Model: I7-8665U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i7
  • IEEE 802.11n
More than 50 in stock
£1,098.06 ex VAT
£1,317.67 inc VAT
Automatically join the strongest Wi-Fi connection available with ExpressConnect. Even without Wi-Fi, experience better streaming, downloading and video conferencing with up to 233% improvement in WWAN speeds gen over gen with the 1.0 Gbps. Stay connected with the first 4x4 dynamic antenna tuning solution in a PC that provides reliable mobile broadband, especially in weak signal areas. The extra two antennas act as additional "ears", resulting in up to 70% faster speeds. Dynamic antenna tuning enables global network coverage without needing to switch parts, and keeps the laptop small with narrow screen bezels.
Keep the work flowing with a high-density battery and ExpressCharge, which allows an 80% charge in one hour. With Dell Power Manager, you can choose between four modes to balance between optimal battery or power performance. Using the Super Low Power panel is 50% more efficient than standard FHD panels without compromising resolution, color or brightness.
With a 4-sided narrow border panel and antiglare screen, you'll be able to work better in front of the screen wherever you go.
  • Work anywhere
  • Power through the day
  • Improved screen
  • Seamless sign on
    SafeID protects end user credentials with optional fingerprint reader on the power button and Smart Card Reader, so you can work faster.
Dell Latitude 7300 - 13.3" - Core i7 8665U - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Platform Technology
Intel vPro Technology
Intel Core i7 (8th Gen) 8665U / 1.9 GHz (4.8 GHz) / 8 MB Cache
16 GB DDR4
Storage
512 GB SSD
Optical Drive
No optical drive
Display
13.3" 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Silver
Image Colour Disclaimer
The displayed product image may be a different colour
30.65 cm x 20.695 cm x 1.845 cm
1.24 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
3 Years Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
4.8 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Platform Technology
Intel Turbo Boost Technology 2.0
RAM
16 GB
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
512 GB SSD - (M.2) PCIe
Display
13.3"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
RGB camera
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3254
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Multi-gesture touch pad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
4-cell Lithium Ion
60 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , HDMI , Headphone/microphone combo jack , USB-C 3.1 Gen 2/Thunderbolt 3
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Silver
Case Material
Aluminum
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.24 kg
10 - 90% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Software applications
Dell Latitude 7300 Core i7-8665U 16GB 512GB SSD 13.3 Bundle deal on Dell Latitude 7300 Core i7-8665U 16GB 512GB SSD 13.3" Win 10 Pro
£1,197.23
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 1000 - 1500
