Dell Latitude 7275 Core m5-6Y57 4GB 128GB SSD 12.5" Win 10 Pro
Quicklinx: C5HFWS00 Mfr#: 790W0
  • IEEE 802.11n
The Latitude 12 7000 Series is the thinnest and lightest 12.5" business-class 2-in-1, designed to go wherever work takes you. With an innovative magnetic connection for quick one-handed transitions, it's always ready to flip into tablet mode at a moment's notice.
Enjoy stunning resolution with the 12.5" Ultrasharp 4K UHD display, optimized for intuitive touch interaction. Every Latitude 12 is constructed with premium materials, including magnesium alloy and edge-to-edge Corning Gorillas Glass NBT, and is finished off with soft-touch paint.
Easily interact with your own personal digital assistant, Cortana, equipped with MaxxAudio Pro by Waves for a natural voice collaborative experience.
Multitask effortlessly with 6th Gen Intel Core M processors and up to 8GB memory. The Latitude 12's two Type-C USB ports and multi-card reader allow you to conveniently link and customize your accessories.
Industry-leading SSD PCIe storage offers lighter weight storage and up to 4x faster data transfer speeds. Built-in wireless technology with the latest long-range 802.11 ac wireless technology makes it easy to surf, stream and stay connected, while the long battery life allows up to 8 hours of unplugged power.
  • Remarkably thin, fully flexible
    The Latitude 12 7000 series is Dell's thinnest and lightest 12.5" business-class 2-in-1, designed to go wherever work takes you. With an innovative magnetic connection for quick one-handed transitions, it's always ready to flip into tablet mode at a moment's notice.
  • Built to last
  • A helping hand
  • Link up easily
  • Faster and lighter
  • Freedom to roam
    Built-in wireless technology with the latest long-range 802.11 ac wireless technology makes it easy to surf, stream and stay connected, while the long battery life allows long hours of unplugged power.
Dell Latitude 7275 - 12.5" - Intel Core m5 - 6Y57 - vPro - 4 GB RAM - 128 GB SSD
Tablet - with detachable keyboard
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Platform Technology
Intel vPro Platform
Intel Core m5 (6th Gen) - 6Y57 / 1.1 GHz, up to 2.8 GHz / 4 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
128 GB SSD
Display
12.5" touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 515
Input Device
Keyboard, touchpad
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac
2-cell - up to 8 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip
Dimensions (WxDxH) - tablet
29.087 cm x 19.285 cm x 0.811 cm
730.7 g
Pricing Type
Build To Plan (BTP)
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 3 years - response time: next business day
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core m5 (6th Gen) 6Y57 / 1.1 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache, Intel Active Management Technology 11 (AMT 11)
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
128 GB SSD mSATA PCIe
Display
12.5"
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
360 cd/m²
Anti-fingerprint, Corning Gorilla glass NBT, BFR/PVC-free
Audio & Video
Graphics Processor
Camera
Resolution
8 Megapixel (rear), 5 Megapixel (front)
Sound
Speaker, two microphones
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Intel Wireless Display (WiDi), Miracast
2-cell
30 Wh
Run Time
Up to 8 hours
Battery Run Time
Wireless on: up to 8 hours
AC Adapter
Input
Output
30 Watt
Connections & Expansion
Interfaces Details
2 x Thunderbolt 3 , Headphone/microphone combo jack , Dock
Memory Card Reader
3 in 1 (SDIO, microSD, microSDHC, microSDXC UHS)
Software
Software Included
Microsoft Office (Trial), Windows 10 Pro 64-bit recovery DVD
Case Material
Magnesium alloy
Dockable
Security
Digital compass, Accelerometer, volume control, gyroscope, Dell Data Protection, ExpressCharge, arsenic free
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter, keyboard
USB-C 3.0 adapter
FIPS 140-2, TCG Certified
Pricing Type
Build To Plan (BTP)
730.7 g
Dimensions (WxDxH) / Weight Details
29.087 cm x 19.285 cm x 0.811 cm / 730.7 g - tablet , 29.087 cm x 19.285 cm x 1.71 cm / 1.4052 kg - tablet with keyboard
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
