Dell Latitude 5500 Intel Core i5-8265U 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: FDZ7WS00 Mfr#: 0PGP0
Display Size: 15.6in
Processor Model: I5-8265U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
More than 50 in stock
£726.67 ex VAT
£872.00 inc VAT
The small 15" mainstream business-class notebook lets you get to work faster than ever thanks to its scalable features, powerful performance and ExpressCharge.
  • Connect anywhere
    Seamlessly work on the go thanks to optional mobile broadband supporting speeds up to 450 Mbps.
  • Travel light
    The Latitude 5500 is more mobile and portable than ever, with an improved design that's thin and modern.
  • Ultimate views
    The display is packed with features designed to keep you focused on your work, like the four-sided narrow bezel and antiglare screen.
Dell Latitude 5500 - 15.6" - Core i5 8265U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache /
8 GB DDR4
Storage
256 GB SSD NVMe
Optical Drive
No optical drive
Display
15.6" WLED 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
35.91 cm x 23.625 cm x 2.2 cm
1.82 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year - on-site
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
256 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare, Wide Viewing Angle, 100 ppi, 60 Hz refresh rate
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
78.6 degrees, RGB camera
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
4-cell Lithium Ion
68 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
3 x USB 3.1 Gen 1 , LAN , HDMI , Headphone/microphone combo jack , USB-C 3.1 Gen 2/DisplayPort
Memory Card Reader
Yes (microSD)
Software
Software Included
Microsoft Office (Trial)
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.82 kg
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
105 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
40 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.26 g @ RMS (random)
Vibration Tolerance (non-operating)
1.37 g @ RMS (random)
Software applications
Dell Latitude 5500 Intel Core i5-8265U 8GB 256GB SSD 15.6 Bundle deal on Dell Latitude 5500 Intel Core i5-8265U 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
£825.84
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 500 - 750
